1950 Transmission
Old Dec 31, 2012 | 12:40 PM
burwellrw's Avatar
burwellrw
1950 Transmission
I am looking for a 1950 Ford F1 floor shift transmission. Any has one or knows where to get one please let me know. Thanks email is burwellrw@hotmail.com
Old Dec 31, 2012 | 12:44 PM
52 Merc's Avatar
52 Merc
Do you want a 3 speed or a 4 speed?
Old Dec 31, 2012 | 12:46 PM
burwellrw's Avatar
burwellrw
Need a 3 speed...
Old Dec 31, 2012 | 12:48 PM
52 Merc's Avatar
52 Merc
What's wrong with your current one?
Old Dec 31, 2012 | 12:50 PM
burwellrw's Avatar
burwellrw
I have a 3 speed column shift in good condition but my son wants to convert to a floor shift.
Old Dec 31, 2012 | 02:53 PM
burwellrw's Avatar
burwellrw
Did you have a 50 Ford transmission or know of anyone that does?
Old Dec 31, 2012 | 03:01 PM
jmadsen's Avatar
jmadsen
if your current trans is in good working order maybe consider just buying a floor shifter. Hurst indy shifters for example work for column to floor shift conversion. just a thought??
Josh
Old Dec 31, 2012 | 03:23 PM
burwellrw's Avatar
burwellrw
Thanks. I would like to keep it original if possible. The motor is out and being rebuilt so it would be easy to put another transmission at this point.
Old Dec 31, 2012 | 03:35 PM
Doc's Avatar
Doc
Don't forget that you'll have to remove the column shift linkage (or at least tie it off and just let it hang there). Plus you'll need a different transmission cover for the shifter among other things. The interesting thing with your case would be to look at the VIN number. The very late 1950 trucks had column shifters. The 48 to earlier 1950 trucks had floor shifters. If you'll give us the VIN number (just X out the last 2 or 3 digits), we can tell you with a fair amount of certainty which shifter it most likely had from the factory.
If I may be curious, why does your son want a floor shifter? Does he think it will be cooler, etc. It can be a PITA for the person riding in the middle.
Old Dec 31, 2012 | 03:46 PM
burwellrw's Avatar
burwellrw
I am certain the truck is original and the column shift came with the truck. The steering is already out of the truck and I can buy a new or used floor pan so it will not be a problem. Right now the body is being worked on and not on the frame. I think it is just something my son would rather have....I guess cooler. the serial # is 98RC508XX
Old Dec 31, 2012 | 03:54 PM
jmadsen's Avatar
jmadsen
I forgot to mention that I do have a 3 speed trans, its been sitting under the bench for a couple years now as im still not quite sure what im doing with it. was in a 48-50 f1 truck with a merc flathead. where are you located? im in Utah.
Old Dec 31, 2012 | 04:16 PM
jmadsen's Avatar
jmadsen
I just called a friend of mine, he has a case and top for a top shift 3 speed he will sell. you can just swap your gear set into that case.
send me a private message or email for more info
Old Dec 31, 2012 | 04:18 PM
burwellrw's Avatar
burwellrw
The truck is a 50 Ford F1 and has the original ford engine and transmission. While the engine is out I was going to have the transmission gone through to make sure everything is good and put new seals etc. but my son asked if we could convert to a floor shift. If you have one let me know how much you would want for it. I live in New Orleans.
Old Dec 31, 2012 | 04:20 PM
burwellrw's Avatar
burwellrw
What is your email. Mine is burwellrw@hotmail.com
Old Dec 31, 2012 | 04:28 PM
jmadsen's Avatar
jmadsen
I just sent you an email.
thanks
