What size wheels?
Old May 26, 2003 | 10:05 AM
s1120's Avatar
s1120
Question What size wheels?
My dads old F6 had big wheels on it. It had douls on the rear. What size did these trucks come with? Loked to be about a 20" wheel. Did they use a lot of different sizes? Thanks.
Old May 27, 2003 | 12:46 PM
CWR's Avatar
CWR
What size wheels?
The best way to check is looking in your shop manual, mine tells what the specs are and also what tire sizes will work.
hope this helps
CWR
Old May 27, 2003 | 02:17 PM
51dueller's Avatar
51dueller
What size wheels?
Does it have tires on it? It should have the size on it or measure from the inside ring to inside ring. The inside ring is bottom of the rim lip. It will be a little off but round up to the nearest number.
