38r boost levels
It sucks when spoken to in a disrespectful way.
I guess it did come across that way. It was not intentional and I apologize. My incessant frustration with the typical list of necessary items that people are forced into thinking they need to buy when trying to increase power finally came to a head and I am sorry that I took it out on you.
As a matter of fact, I have the same gauges you do. I rely on the OBD2 port for very little information because what I want to see isn't available; everything else is useless if the truck runs ok. Heck, the last time I used any scan tool for 7.3L diagnostics was a few weeks ago; after over six months of not touching one. My belief (and it's certainly not for everyone) is the feeling regarding the necessity of a boost pressure gauge because all it does is move around without giving any real data; but it's data on which people base performance capability. Truth be told, I have owned more than a couple stock 7.3L trucks and I have NEVER, EVER attained more than 15 PSI of boost in a stock state yet everyone and their mother claims that 17-18 PSI is the "norm". Does that mean that there was something wrong with these trucks? No. I would have chased my tail for months trying to figure out where in the world those pesky, elusive 2-3 PSI were hiding (and the HUGE power I was missing out on
) if I didn't know better. It seems like the "acceptable" numbers creep up over the years and then someone comes along and knocks them down. The bar then slowly keeps getting raised again until someone calls it out. Rinse, repeat. I have an EV2 boost gauge (one in both of my personal trucks). There is no defueling going on anywhere. 50 PSI of drive pressure and 22 PSI of boost is right where my particular truck likes to run with the particular parts it has. It will run a higher boost level than that, but I can't see two counter-productive anomalies helping anything out; increased heat from a higher level of compressed air and increased drive pressure that does nothing but make the engine work harder for what it gets in return. Also, with valve springs having 256K miles on them, I don't want to "overpower" them with drive pressure trying to creep back into the cylinder. Airflow is paramount. The deciding factor on the absolute mass airflow through the engine is dictated by the area between the exhaust port beginning at the back of the valve and the turbine outlet; wastegate not withstanding.
As seen by just about everyone here, the compressor on a stock OR drop-in aftermarket turbocharger is capable of moving more air than the base engine can efficiently flow, otherwise we'd run at ambient manifold pressure (zero boost). However, the big restriction that causes the back-up (constipation) in the system is the region outlined in the previous paragraph. If you can't get the spent exhaust gasses out, you will not get any more air flowing through the engine. It's an absolute. Any air density (seen as boost) above what the exhaust side is able to accommodate just results in more boost with no additional gain in performance. Pressure above ambient creates a higher air density (read: more oxygen molecules in a given space) than ambient. This higher number of oxygen molecules gives us our power when "spooled" because we can effectively burn more fuel. The more fuel we can burn efficiently, the more power we can make.
However, air density is not equal to, nor is it related to actual airflow. This is where my big argument comes from. People with stock (or stock replacement) turbochargers that are hung up on making "big" boost numbers. At that point, boost becomes a number and a fun gauge needle to watch.....and that's it. Bigger is better, right? Think of it this way: If you have no exhaust restriction for driving the turbine, but you have a compressor that is moving a TON of air, what would the boost pressure be versus having a restrictive turbine that doesn't flow as much? In the first case, you'd have a TON of airflow but little "boost". In the second scenario, it would be just the opposite. If I could get the turbo response of the first setup (it would suck on the street), I'd take it in a heartbeat even though I could pretty much use a mechanical fuel pump pressure gauge (0-7 PSI) to monitor my boost at that point.
There is an instance where higher boost levels do help. However, running a small single turbocharger is not that instance. There is a reason people who make the BIG power on big single (with positive boost/drive pressure ratios) and compound setups with accurately set up wastegate systems can make HUGE boost numbers and still make power. It's called "airflow".
As we can see, there is a magnificent trade-off with turbochargers. Either flow a lot of air and hope that the truck moves out of it's own way before building enough heat and pressure to run the turbine, or use a turbine that chokes us on the high end but gets our cylinder air density higher, quicker.
Again, Rich, sorry about the earlier diatribe.
My big problem with "mods" comes when people do it to their daily driver or their only vehicle and then get really pissed off when the truck doesn't start or run right (or blows up) and they can't get to work or their wedding. The truck in question here (my 2000) is one of four vehicles I have. It's 2wd so it's useless in the winter (albeit REALLY fun until it doesn't move without a tow strap) and it was purchased for ONE reason and that is to play with. It's a toy. I LOVE driving it because it's comfortable and low-stress; I do drive it most every time I can, but I don't NEED it. Heck, I put more miles on it over the year than any of the others but if I break it, so be it. I have another mode of transportation in that case.
It's got 256K on it, it's all stock other than injectors and the muffler (which is also a genuine Ford part). It's nothing more than a cheap, fun, and relaxing toy to me. In addition, it gets really good fuel mileage when I drive it nice. It's wonderful to be able to drive 600+ miles between pee-stops when driving across the country.
The moral of the story:
If you truly rely on the vehicle for daily life, don't spend a ton of money on it making it unreliable or finicky.
The truck in question:
Great info! Much of what you said covers a number of things that have come to my attention with the new injectors. My mod to a bigger turbo was to prevent damaging the stocker because I was already maxed out. This new one breathes nice and has a whole different "note" to it, but I did see the engine get real whimpy when I had the red line adjusted to dump anything over 22 PSI (not to mention the contrail-O-coal that showed as a result). Adjusting the wastegate to 35 PSI really stepped up the power, but I am not inclined to go any higher.
I was talking with 2000ca 250 and he replaced his valve springs. He mentioned there was a huge difference in performance (he has really big sticks, dual HPOPs, and bigger air). I don't know where the threshold is for the springs feeding the exhaust back into the cylinder... it's going to be different for every truck. I can see where weak valve springs and too much boost would rocket the pyrometer, but the acceleration would dip with this scenario (in my way of thinking). My experience (to date, with both sets of sticks) gives me more acceleration with a higher boost number. I could tinker with backing off the go pedal to regulate the boost down to 30 and see if I can feel a difference, but it takes just a few seconds for these sticks to poke at blue strobe lights. I'd need to get somewhere secluded to conduct this test.
Just as the text near my avatar declares, I am a cautionary tale. Going bigger on one thing means everything before and after that one thing needs to feed it and let it out. I blew a plenum seal on the first romp with my new sticks and turbo. I'm looking at my next intake upgrade to feed "Garrett". As Cody suggests, I might approach the need to replace the valve springs. I want to learn what more I can do with tuning to increase Stinky's lifespan, yet keep that Crackerjack surprise inside for when I open 'er up. I'm already driving Stinky like grandpa most of the time to increase the life span and get better fuel economy, but once in a while....
I drove it for the last time with 160/100% injectors today. Tomorrow, the injectors will be in a truck belonging to one of my brother's co-workers. I'll miss it until late spring.......
