Almost a fuel filter change diaster
Old Dec 28, 2012 | 04:09 PM
Olds69442's Avatar
Olds69442
I changed my oil today and said let me do the fuel filters while I am at it.
Used a socket on the DFCM, felt snug, so I said to myself, just a little more force should do it. The bowl came of easy the first time.
Well, it did it. See pics below.
This is the second fuel filter change for me, the first one was no issue with the socket. I broke out the strap wrench and off she came with a bit of persuasion.
Two pieces of good news, One is I bought an extra bowl about a month ago. The second, the bowl looked pretty clean.
Had to move the WIF sensor and the drain valve over to the new one.
Of course while I was purging the system, I did not get the return connection just right on the engine filter. You get quite a bit of fuel out, and it goes everywhere.
Took her for a drive, and filled up. All is well.
My lessons learned:
1. Strap wrench.
2. Speed kills.
3. Double check fuel filter connection.
4. Have extra bowl on hand.
Old Dec 28, 2012 | 04:31 PM
kper05's Avatar
kper05
I need to get a spare bowl.
I have put that off since the first filter change.
I'll be due for a third in about 3,000 miles.
Old Dec 28, 2012 | 05:17 PM
Docindahouze's Avatar
Docindahouze
Can you give the part number for the bowl. Thanks.
Old Dec 28, 2012 | 05:44 PM
marchare011's Avatar
marchare011
My lessons learned:
1. Strap wrench.
2. Speed kills.
Good advice, Tony.
Old Dec 28, 2012 | 05:46 PM
Olds69442's Avatar
Olds69442
<TABLE id=ctl00_MainContent_gvProducts class=grid_noborders style="BORDER-COLLAPSE: collapse; WIDTH: 100%" cellSpacing=0 border=0><TBODY><TR class=gridrow><TD>CAP
Part #: BC3Z9G270C
</TD><TD>$13.32 </TD><TD class=gridcell-center>1</TD><TD class="gridcell-right gridcell-subtotal"></TD></TR><TR class=gridrowalternate><TD>PLUG ASY - PUMP
Part #: BC3Z9J305B
</TD><TD>$4.40 </TD><TD class=gridcell-center>1</TD><TD class="gridcell-right gridcell-subtotal"></TD></TR><TR class=gridrow><TD>SENSOR - FUEL TEMPERATURE
Part #: BC3Z9T321A
</TD><TD>$18.78 </TD><TD class=gridcell-center>1</TD><TD class="gridcell-right gridcell-subtotal"></TD></TR></TBODY></TABLE>
I just ordered the following parts. The drain plug I am not to concerned about. The WIF sensor had a o-ring/washer that I had to reuse. I am planning on keeping an eye on it.
I order this from Allegheny Ford here in Pittsburgh. I paid $31 for the cap last month. It is $13 this month.
Old Dec 29, 2012 | 06:16 AM
Adobe 11SD's Avatar
Adobe 11SD
Great information. I am going to see if one of the local dealers has the cap this morning.. Thanks.
Old Dec 29, 2012 | 09:10 AM
ruschejj's Avatar
ruschejj
It is common to lube that big o ring for the bowl. I always spray wd40 all over it.
My life is crazy, I drive a little more than 5,000 miles per month, so I'm changing fuel filters every 3 months. The only good part is that the fuel bowl gets moved 4 or 5 times per year, so mine never seizes.
Might be a good idea for you normal folks to spin that bowl once in a while to keep it from sticking. Maybe add it to your maintenance routine when you drain the water separator.
Old Dec 29, 2012 | 09:19 AM
gsxr1300's Avatar
gsxr1300
If it cracks do you need all 3 parts? I haven't changed fuel filters yet
Old Dec 29, 2012 | 09:44 AM
Olds69442's Avatar
Olds69442
No you do not need all three parts. I only bought the bowl the first time and transferred everything else over. I have a concern with the WIF sensor since it had a o-ring/washer I had to reuse. I am buying the replacement just in case.
Old Dec 29, 2012 | 01:00 PM
McFarlandkm's Avatar
McFarlandkm
I am not sure of the composition on these particular orings, but generally you should avoid wd40 on rubber items. In the jet turbine industry we use petroleum jelly or jet fuel on fuel systems and engine oil on oil systems. Lubing the oring also prevents it from twisting or rolling during installation.
Old Dec 29, 2012 | 06:12 PM
ruschejj's Avatar
ruschejj
True, good point.
Old Dec 29, 2012 | 06:44 PM
Hdslider's Avatar
Hdslider
Those green o rings are silicon and can take just about anything you ca n put on them. There used in diesel sytems, gasoline systems, ac systems.nitro, on and on. Its the black rubber orings you gootta really be careful.
Old Dec 30, 2012 | 01:21 AM
Adventure Rider's Avatar
Adventure Rider
When I redid my fuel filter last week I dipped it fully in the diesel fuel and gave it a quick swipe to remove excess
This allowed to properly tighten the assembly
Great post and thanks for the information
Old Dec 31, 2012 | 12:06 AM
biz4two's Avatar
biz4two
Arrow
GREAT post with pics! Reps given...
But...seems like a faulty "weak" design...IMHO.
biz
Old Dec 31, 2012 | 07:02 AM
capt caper's Avatar
capt caper
My lessons learned:
1. Strap wrench.
2. Speed kills.
Same exact thing happened to me to the T. The pictures look just like mine. I use a strap wrench now I made out of a wood handle and nylon web. Used only for that filter.
