2002 Explorer -Sudden loss of power
4.0L 184,000 mi
Driving home on highway, suddenly had problem maintaining speed. Got off exit. Seemed to idol OK, but stepping on gas only wanted to go very slow (some rattling sounding like heat shield?). Got it home and replaced the fuel filter (rented fuel pressure gage mistakingly showed no pressure at first) but fuel pump working. Same problem. No codes.
I believe timing chain had been getting noisy (been reading lots about that - happens around 2400 rpm and quiets after oil change).
Question. Could the chain have jumped a tooth? Would the symptoms be as discribed? Any other possibilities?
Of course holiday weekend here, thinking of towing to dealer, but value the opinions of the Forum!
Thanks. Happy New Year!
Thanks Aquanaut20.
First, following my Haynes manual, I connected a vacuum gage to the intake and saw it drop and slowly recover after revving several times. Next, removed right side upstream O2 sensor and repeated the vacuum test. No drop, just retruned to idol level. Took it out for a ride around the block and it was definately (maybe not perfect) much more powerful than the other night. So I'm looking into replacing with a direct fit cat - any knowledge about Eastern brand (about 100 cheaper than Walker)?
vacuumbed
34
08-02-2019 04:33 PM
jnye6625
10-10-2004 09:11 PM
drpepper
09-16-2002 09:12 PM
