Door opener cables?
Old Dec 28, 2012 | 08:49 AM
gyrocopter1's Avatar
gyrocopter1
Door opener cables?
I have a 97 E150 and a 2001 E250 . The cables inside of the doors
on both or these vehicles have failed,Who designed this crappy system
to operate the the door catch. The problem is the ends which are made of some kind of plastic which breaks after a few years. On the 97 the rear door cables let go 2 yrs. ago, on the side door both cables broke at the same time, couldn't open the door, had to remove all door trim just to get it open then Ford wants $50.00 plus for two cables about 12" long with the same weak ends. Has anybody else had this problem and is there a cheaper source of replacements?
Old Dec 28, 2012 | 11:34 AM
95e150CW's Avatar
95e150CW
There was a guy selling aluminum repair ends on ebay, was like 25 for two.
Old Dec 29, 2012 | 05:19 AM
JWA's Avatar
JWA
I'm in the auto glass biz and oddly enough I've experienced this only once---on a '97 E250 I bought used, very, verywell used!
When you replace the cables check for proper door latching, make sure the latches themselves aren't in a bind or hanging up. This can put a tremendous strain on those cable ends as well as stretch the cables since excessive force is required to release the lathes from their catches. A door misaligned can be part of the problem too.
I know this is one aggravating problem when it occurs but honestly I don't see it that often in my biz. Its mentioned from time-to-time here which makes sense as this is the van forums!
Hope your solve this cheaply----love to know your eventual fix!
jtug69
Jun 26, 2019 01:49 PM
hvphotog
Feb 2, 2017 01:37 PM
oldfordtrucksrule
1997 - 2003 F150
Mar 10, 2015 08:02 AM
Mocha Joe
May 29, 2013 05:34 AM
hungry_aggie
1997 - 2003 F150
Nov 12, 2011 06:26 PM
