Stinky's runnin' great! Now the go needs attention.
So... my Buck$Zooka may not be ready for shrink-wrap just yet. I have a vibration (or shudder) in 3rd gear. I know bupkis about transmissions and I have no plans to be a guru in there. I will instead share my observations, seek input, and let the transmission folk slap me around and make me write checks. Injectors have sucked all the fun out of turning wrenches on Stinky until spring. Chipping may void the warranty, so I pulled the chip the last time I had the stealership look at it in October of 2011. I'm pretty sure I can't hide the recently-added sizable single-shot sticks and custom tune to make them run, so that warranty paperwork might have a "remit payment" line at the bottom.
Thoughts?
- HD4R100 installed in August 2011
- All gears have a solid (but not slamming) shift.
- My transmission runs real cold - just 70 degrees above ambient, so it's 100 degrees in there this time of year.
- 3rd gear vibrates under cruise to moderate load, but the vibration disappears when I let off the accelerator or push deeper in the accelerator.
- I notice it more when I'm in four-wheel drive.
- All other gears are baby-butt smooth.
Thoughts?
I too say check U joints and carrier bearing....1, because it sounds like a RPM related issue/load issue, and 2, because they are all easy to deal with. What RPM does it occur at? I'm guessing its more when you are cruising than when you are getting on it at all, so I would guess between 1500-1900...If thats the case I would put more money on u joint or carrier bearing...only thing that is throwing this off is the fact that it is more noticeable in 4x4...
Maybe the vibration is augmented by the imbalance with the front drive in 4X4 and the two drives start dukin' it out in 3rd. After all, the rear now has to argue about the speed... rather than just be in charge.
If 3rd in an auto is indeed 1:1 then there might be a vibration that you feel in the driveline at a certain driveline RPM...the reason for it showing up in 3rd would be that the engine is turning the same RPM as the drive shaft allowing you to actually notice the vibration. My bet is on carrier bearing or a driveline came unbalanced.
Results:
- Bent driveshaft (that ought to cause issues). It was out by 20 thousandths, near the carrier bearing.
- Front U-joint had a little "burling" (I think that was the term) on three ends (side, tangs... whatever they're called), but the other two U-joints were in excellent condition. All three were destroyed while trying to remove them to inspect them. I watched the process and those buggers were stuck in there pretty good... I could never remove them with the tools and skills at my disposal.
- The old weights on one shaft made it out of balance, and removing them solved the problem. The other shaft had weights 160 degrees out from where they now need to be.
- Dry splines... but I already knew that.
- Carrier bearing is in excellent condition.
Hmmm... I looked right over that... good point. The problem has been there a while, but far more subtle. I noticed it more since my 3rd-gear scratch during a WOT test in 80e (now omitted from my tuner). It has grown worse as my injector issues may have exacerbated the problem with the incessant torque romps. It wasn't until the engine was smooth that I could isolate the vibration to the drive. There are just too many things on the list that could have been the root cause, or more likely... everything added up.
The torque converter can cause this as well. This is one of those buggers that's a process of elimination. Depending on miles and treatment, your driveline may need to be looked at... but the transmissions on these are not that robust and are a tall blip on the suspect-o-meter.
