302 capabilites?
Old Dec 27, 2012 | 12:35 PM
MarkG.'s Avatar
MarkG.
302 capabilites?
Im thinking of putting a 302 with a t-18 or t-19 into my f5 flatbed, but am wondering if it would have the same capabilities, load wise, as the stock engine and trans. I still plan to use it as a work truck for hauling and towing does any one know? thanks. MarkG.
Old Dec 27, 2012 | 02:00 PM
MarkG.'s Avatar
MarkG.
Sorry I meant a NP435. Not a t-18 or 19.
Old Dec 27, 2012 | 02:14 PM
85e150's Avatar
85e150
Which 302 and what cam?
If you have a PU truck 302 with the lower end type cam, it will probably work just fine. A Mustang motor might not work so well.
You will have plenty of gear with the NP 435. Make sure you get the biggest, most heavy duty clutch you can find for it also.
Old Dec 27, 2012 | 02:57 PM
MarkG.'s Avatar
MarkG.
the 302 is from a 84 f150.
Old Dec 27, 2012 | 03:54 PM
52 Merc's Avatar
52 Merc
The 302 has twice the hp and torque of any of the stock engines available at the time. So if that's your comparison, you'll be in good shape. Obviously, for working purposes, there's many larger engines available that would do a better job.
Old Dec 27, 2012 | 06:06 PM
old_dan's Avatar
old_dan
The 302 is a great engine. The 80's engines had the cam timing retarded to help reduce some emissions. As long as you have it out and accessible, you could gain quite a bit of power by putting in an aftermarket timing gear/chain set, and maybe even a towing type cam. If you put the valve timing back where it belongs, the engine will run a lot better. It's just a thought. It all kind of depends on what you're planning to use for a fuel system (fuel injection or carbureted). I had an 84 Bronco years ago & it had the crappy carburetor with no adjustments. Not too long after that, they went with fuel injection. That one was the 300-I6 engine & it went through 3 exhuast manifolds in the first 100k miles. I assume it was from excessive exhaust gas temperature which is a result of the cam timing being retarded.
With 34 posts, that makes you a relatively new guy....Welcome to the forum!!
Post a couple of pics of your project!
Dan
Dan
Old Dec 28, 2012 | 06:43 PM
mrsixpack's Avatar
mrsixpack
I used a stock 302 and C4 trans in my 3/4 ton 1952 truck. with stock rear end and tires....it hauled a 10.5 foot camper loaded with all my tools from Calif to Oregon with no problems.....it would pull heavy loads all day.....not fast (55mph max) but never slowed down on any mountains. lost it in divorce but it still is my #1 truck ! Never had problems with engine or trans.
Old Dec 29, 2012 | 12:13 PM
BigBlockMan's Avatar
BigBlockMan
I agree with Old Dan. I doesn't really matter what the 302 came out of, they all had dish top pistons and no cam(except the 5.0L's out of a late model Mustang). I'd call Comp Cams and ask them to suggest a cam. You will have to know everything about your truck and motor though.
Old Dec 29, 2012 | 03:08 PM
carnut122's Avatar
carnut122
That's what I was thinking too.^^^^^^^^^^^^^
Old Dec 31, 2012 | 09:51 AM
Fordman49F1's Avatar
Fordman49F1
You won't have issues with a stock 302. While it is out, you could build yourself a little more reliable HP and TQ without sacraficing durability, but in reality you don't have to. You could leave it in stock trim and out perform a flathead with it any day. They offer more ponies, more torque, and can reach more revs than the flat could. So...by that statement, you are good.
Now would a very mild cam help? Yep. Better pistons? Yep. Do you hafta do it? Nope. There are larger displacement mills available, but honestly there is nothing wrong with what you are looking at.
rmalottwtes30
Oct 17, 2006 05:40 PM
Fordever2
May 25, 2005 09:19 AM
335clevo
May 27, 2002 06:48 PM
airharley
Jan 30, 2002 08:27 PM
