74 390 issues
Old Dec 27, 2012 | 04:42 AM
rdweathers's Avatar
rdweathers
74 390 issues
I thought i had a blown power valve in my holley, so i did a few checks before taking the carb off, with the engine running yesterday i noticed some blue smoke coming from what looked to me between the fire wall and back of block. I have posted other issues i am having with this engine the day before somehow i think they are all tied together. I have never seen blue smoke out the exhaust, do not have exhaust leak, there are no oil leaks, i could eat of motor its that clean, it was not coming from PCV or the oil filler cap, i had the air cleaner off so i could see everywhere, when this smoke was coming out it was running not bad but not right either, then the smoke stop and it started running correctly. I have an aluminum eldebrock intake, all the bolts are tight. Anyone had a problem like this?
I never had an issue until i did cam, intake, and carb upgrade. I also replaced the head gaskets. I did all this about two years ago and 2k miles, had a worst problem back then turned out its was the intake gaskets.
When i had the heads off, i replaced the valve seals, when i inspected the head, i thought to my self the valves sure looked like they were recessed further in the head than what they are supposed to be, never thought i had an issue with the engine because it ran good, and now after doing research this is not nromal and could be an issue, any thoughts? I could tell the block had been rebuilt at one time and once again never thought there maybe head trouble. Is it possible these valves stick after a long run and would cause my skip after stopping but go away after taking off and will not do it during normal stop and go traffic?
ErrorS
24
Jul 6, 2007 08:06 PM
mtpcage
Jun 21, 2006 07:37 AM
Steve A
Dec 2, 2004 10:31 PM
bigric
Feb 3, 2004 03:13 AM
lsrjf
Jul 27, 2002 08:37 PM
