I picked up a complete D60 out of a '99 Dodge years ago for cheap. I finally have had enough of my TTB and want to swap it in. I will need to put lockouts on the D60 and find a different right side axle shaft since the Dodges use the split axle with the vacume operated lock thing in the middle of the right side shaft.
What will interchange off my D50 TTB onto the D60? will any of the outer parts work like the spindles, rotors, calipers, or will I have to find new parts. My hope was the D50 would work and all I would have to find is the axle shaft.
