1978 - 1996 Big Bronco
serpentine belt
Old May 26, 2003 | 12:55 AM
bronco cam's Avatar
bronco cam
serpentine belt
Have any guys got any ideas how to fix a noisy belt? I have a 96 bronco and I seem to be going through belts. Had one that was noisy so I replaced it and less then 200 miles it has started making noise. My 94 f250 had the same problem but I would get a lot more miles out of a belt. My bronco sat for a year with out a hood or fenders and there is some surface rust on my pulleys could that be the problem? Other then that I only have 60000 on the bronco. Let me know its driving me nuts.
Old May 26, 2003 | 01:01 AM
steve83's Avatar
steve83
serpentine belt
Definitely clean & deglaze all the pulleys, and make sure they're all parallel.
Old May 26, 2003 | 01:22 AM
bronco cam's Avatar
bronco cam
serpentine belt
What do you think I should use for cleaner? Could my tensioner be bad? It was loose when I boght the bronco but I tightened it back up and it seems to work. I think while they were stealing the fenders and hood and everything else they started to take the tensioner. I also notice a lot of black residue like its eating my belt. I hate ford belts, like I said I have had this problem before on other ford trucks just not as bad.
Old May 26, 2003 | 01:49 AM
bronco351's Avatar
bronco351
serpentine belt
I agree with Steve. You definetly need to clean the rust off those pulleys. Some Brake Cleaner and WD-40 should get the rust off. Then you need to coat all the pulleys with belt dressing. It will help the belts stick better. Then make sure your tensioner is tight. Don't overtighten it just look at the gauge on the tensioner and make sure it is in the correct range.
If you can't clean the rust off the pulleys then you will need to pick up some new ones. Also make sure all the pulleys are turning freely. A stuck or close to seized up pullley will make quick work of any new belt. HOPE THIS HELPS!!!!
Old May 26, 2003 | 01:10 PM
steve83's Avatar
steve83
serpentine belt
I wouldn't ever spray WD-40 on the pulleys - it contains a LOT of wax, which will just reglaze them. If there's any grease or tar on them, use engine degreaser & hot water before you wire-brush, sandpaper, or sandblast them. Then maybe spray some clearcoat or black paint on them.
Old May 26, 2003 | 03:41 PM
bronco cam's Avatar
bronco cam
serpentine belt
Thanks guys. But I think I found the problem. I think my tension pulley is bad. Is it suppose to move back and forth or vibrate when reving my motor?
Old May 26, 2003 | 11:13 PM
greystreak92's Avatar
greystreak92
serpentine belt
No, the tensioner pulley should remain tight throughout the RPM range. Definately replace that little sucker.
Old Jun 18, 2003 | 03:12 PM
mweeps's Avatar
mweeps
serpentine belt
So the pulley is not supposed to move at all? I am going to replace my belt and I may need to replace the tensioner along with the idler pulley. The Idler looks as though it was replaced before but it has flat spots on it.
Old Jun 18, 2003 | 11:46 PM
greystreak92
serpentine belt
Yes, if the tensioner pulley loosens when you rev the engine its the equivalent of your tires cutting loose from the pavement. Things spin like heck, but they don't move...also drags against the rubber and wears it down faster. In the case of the belt, it is the primary cause of pulley glazing. The rubber sliding across the surface of the pulley tends to make the pulley more susceptable to letting the belt slip. Wears out the belt faster too.
Old Jun 19, 2003 | 01:22 AM
mweeps's Avatar
mweeps
serpentine belt
I am not sure if I need to replace the tensioner or not? It is still against the belt but the pulley moves left to right as it turns. It is an automatic tensioner so I thought that the movement is to keep the tension? Could some one explain it a little better? I want to replace it if needed. Does anyone have some pics of changing one?
Old Jun 19, 2003 | 01:32 AM
bronco351's Avatar
bronco351
serpentine belt
I think it has already been explained twice. Someone please correct me if I'm wrong!!
Old Jun 19, 2003 | 02:10 AM
mweeps's Avatar
mweeps
serpentine belt
Is there any difference in brands of tensioner? The Ford part lists for $54 and you can get a Dayco from Advance for $64? Which is weird that the Ford part is cheaper, but Ford lists the Idler pulley for $84 and it is $14 from Advance ? What gives (apparently not the tensior bronco351 )
Old Jun 19, 2003 | 06:30 PM
mweeps's Avatar
mweeps
serpentine belt
I went to Local Ford Dealership and they have the Idler pulley for $24 and Tensioner for $54. Not in stock of course they have to order it won't be in until Tuesday
Old Jun 19, 2003 | 07:13 PM
bronco cam's Avatar
bronco cam
serpentine belt
Got mine at kenechts auto parts for 52 bucks , tesioner and pulley
Made by dayco.
Old Jun 20, 2003 | 04:11 PM
mweeps's Avatar
mweeps
serpentine belt
I am going with Ford parts on this one. The flatspotted idler pulley is a Dayco that was replaced previously.
