Freeway gears
Old Dec 26, 2012 | 07:23 PM
ALBUQ F-1's Avatar
ALBUQ F-1
I'd be worried about the load rating on the freeway. Most 175/70-14's I saw were rated around 1,000 lbs, which is right about the load you've got on them. That doesn't include any cornering loads...
At any rate, an overdrive looks like a viable option, and since you already have a C4, an AOD is a virtual drop-in.
Old Dec 26, 2012 | 07:28 PM
second_chance.custom's Avatar
Let me ask all you guys this. Is the higher the ratio lower top speed or is it the other way around?
Old Dec 26, 2012 | 07:30 PM
Just to sum it up. Yes the style is a big plus. As for the load rating. Only other thing going in or on the truck is me and my girl.
Old Dec 26, 2012 | 07:53 PM
52 Merc's Avatar
52 Merc
The higher the ratio (which means the lower the number) the greater the top speed you'll be able to achieve.
52' fordnut
Aug 18, 2012 07:41 AM
Will Chiello
Mar 2, 2011 03:52 AM
davewave649
18
Feb 18, 2010 02:47 PM
Huntersbo
Mar 3, 2007 11:22 PM
Tepot
Jan 1, 2005 06:03 PM
