Rear end question
Old Aug 17, 2012 | 05:17 PM
52' fordnut's Avatar
52' fordnut
Rear end question
Hello,
I am in the process of rebuilding a 52 Ford F1 and I am going to put a 302 with a c4 transmission. I have purchased a gear ratio set and a 9 inch rear end to drop into the truck.
But recently I have heard where a lot of people have been using the stock rearend with a 302 and c4 transmission. Is this a good option? To use a stock rearend with the c4? Im curious as to if this would be better to do than putting the 9 inch rearend and the new gear ratio set in the truck.
Thanks for the help,
Jon
Old Aug 17, 2012 | 06:35 PM
Aarons54f100's Avatar
Aarons54f100
I just posted on another thread fairly similar.
If it is the stock Dana 41 then the gears are pretty low. 3.73,3.92, and 4.27 were the options available according to a few pages on this website.
That being true I do not know what kind of horse power these handle. Those gears would squall the tires at the redlight and eat up gas on the interstate. Depends on what your goals are.
If it were me, and you wanted to have some good acceleration and not die at the pump Id go for 3.00 3.11 or 3.25. The higher the number for more acceleration and higher rpms on the interstate.
Edit:
Example being. 4.27 gears, with 27 inch tires, in a typical automatic without overdrive, would do ~4100 RPM at 75 MPH
3.25 gear, 27 inch tires, auto without OD, would do 3115.
3.00 - 2875 rpm
2.75 - 2635 rpm
I seem to remember reading a ford 9 inch, 28 spline axle is good till around 425-450 horsepower. Any more and you want 31 spline or very very cautious about wheel hop. That is hearsay though, I have no experience to back it up.
Old Aug 17, 2012 | 07:11 PM
52' fordnut
Hey, thank you guys so much! I really appreciate all of the help!!
I had posted a similar question on another thread earlier in the week.
Thanks again guys
Jon
Old Aug 18, 2012 | 07:41 AM
GreatNorthWoods's Avatar
GreatNorthWoods
My 49 F-1 has a 302 and FMX transmisison. I'm using a Chevy 10-bolt rear with a ratio of 3.08 with 225:75/R15 tires. In my case I wanted taller gears for better gas mileage. It depends on how you drive your truck and what you want out of it. My truck is a cruiser and performance is not as important to me as gas mileage. According to various gear ratio calculators my truck should run about 2000 RPMs at 55 MPH and about 2550 RPMs at 70 MPH which is about where I want it....
beaker1671
Dec 1, 2024 06:15 AM
second_chance.custom
18
Dec 26, 2012 07:53 PM
kedwinh
Aug 3, 2011 03:59 AM
impalaslayer
Mar 1, 2011 10:10 PM
Sayer Lane
May 16, 2009 10:57 AM
