Spool in 9"
Old Dec 25, 2012 | 01:48 AM
67-F100's Avatar
67-F100
Spool in 9"
Thinking of getting one for my 67 F100, and have a quick question. There 28 spline right? And would I need to do a c clip eliminator? What's the point of doing the eliminator?
Old Dec 25, 2012 | 06:49 AM
critterf1's Avatar
critterf1
9" doesn't have "C" clips.
Old Dec 25, 2012 | 07:58 AM
Freightrain's Avatar
Freightrain
Been running a full spool in my '69 for 20 yrs now. Just have to watch how you drive it if you do go out in wet weather. It will be a handful. Mine stays on dry roads. Pushes pretty hard going around corners, even worse with only 4" front runners on the nose.
Yup, c clip eliminators are for 8.8 rear ends.
Old Dec 25, 2012 | 10:32 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by 67-F100
Thinking of getting one for my 67 F100, and have a quick question. They're 28 spline right?
B7TZ-4234-A .. Axleshaft-28 splines / 1957/67 F100.
Old Dec 25, 2012 | 11:19 AM
f100today's Avatar
f100today
9 inch rear ends do not have c-clips. And regardless of what people say; if it is a regularly driven street truck, it will suck to turn.
Old Dec 26, 2012 | 01:25 AM
3.3 Over's Avatar
3.3 Over
Y do you want a spool?
Racing it? Four wheeling?
I was thinking same thing my self, for off road; prefer a Detroit but until I find one I'd Putin a cheap spool or weld it to be honest, but mine is 90% off road, 10% parked in my shop lol
Old Dec 26, 2012 | 08:18 AM
Freightrain
Welding will fail in the most unopportune time. Mini spools are not much better with just that single pin driving two large wheels. Shock it one time and "snap", you're stuck.
Best bet for a non failing issue is a full blown spool. Not as cheap, but won't let you down someday later.
Yes, spools on the street are not alot of fun. Been there for over 20 yrs. It's not a daily driver though so I put up with the tire hopping, screeching while turning, understeering problem.
Old Dec 26, 2012 | 08:27 PM
67-F100's Avatar
67-F100
It's going in a weekend little street truck, it won't be driven much. Gonna be on the original street tires, no slicks so I wouldn't be putting much stress on it I think, and I will by the aftermarket pin for it. I just want a locked diff for those late night races or burnouts. Haha.
Old Dec 26, 2012 | 11:18 PM
HIO Silver's Avatar
HIO Silver
Why not opt for a Powertrax by Richmond Gear? .. Much more friendly than a spool on the street.. and ya don't need to have the ring and pinion set-up.
POWERTRAX® EXTREME TRACTION SYSTEMS
Old Dec 28, 2012 | 05:34 PM
BobbyFord's Avatar
BobbyFord
I say run a stock 31-spline Trac-Loc or get a Detroit Locker.
This is a factory 31-spline Trac-Loc...
millertme
Jan 14, 2014 01:15 PM
redneckmoe
Jun 3, 2011 06:31 AM
71fordkid
Aug 6, 2009 05:55 PM
bsprowl
Jul 30, 2007 01:26 PM
