f250 rADIUS aRM bushing HELP
Old Dec 23, 2012 | 09:55 PM
Redmanbob's Avatar
Redmanbob
Question f250 rADIUS aRM bushing HELP
This probably belongs elsewhere, but I like you folks more LOL! Snapped up a 1971 F250 Camper Special Custom this weekend for a $K out in Menifee CA. The truck needs the radius arm on driver side replaced. It's GONE. and to boot it seems whoever may have done them before left out the cups ? I only see the washers ???? I have the 66's unit behind the garage and plan to steal the cups from it for the meantime. Did this year/model.... not use cups ? I cannot believe that is the case, my guess is that some dilbert didnt make a note of how they came apart, put it back together and decided to pass on making it right after realizing it wasnt. Alot of work to correct if the cotter pin installation is when you have a light come on.
IIRC, I can remove the coil spring clamp/s at the top and pull bolt from Ibeam. Slap on the bushings and go. But I recall the 66' Ibeam pressed in bushing was shot and that made for some real fun in the driveway!! With this ones bushing GONE, I expect this IBeam bushing to look quite similar.
Please chime in with advice, it always helps to have to food for thought prior to attempting a task your only simi familiar with.
Old Dec 24, 2012 | 07:24 PM
Redmanbob's Avatar
Redmanbob
WOW!!
THIS PLACE IS A GHOST TOWN HUH!! WONDER WHAT HAPPENED.... anywho.. got the bushings in and the truck running quite well. drives like towncar man!!
1971 F250 Camper Special Photos by GrumpyBobby | Photobucket
Old Dec 25, 2012 | 08:54 PM
1972RedNeck's Avatar
1972RedNeck
This place is for FE's and FT's in general. Your question should have been in the '67-'72 section.
AubreyA3
Feb 20, 2015 02:24 PM
metriccar
Jun 3, 2012 12:47 AM
frodomonster
17
Oct 26, 2011 10:07 PM
352 blue
Oct 26, 2004 04:19 AM
