Key wont turn
Old Dec 23, 2012 | 07:10 PM
dtgl90vt's Avatar
dtgl90vt
Key wont turn
Hey guys,
Well I made it home for the holidays and I want to get my truck back on the road and had a list of some fixes to do, but It has been sitting for about a month so I wanted to start her up today, so I get my key I go out and figure I will let the glow plugs cycle a few times, BUT when I go to turn the key, it would not budge at all.
I can turn the steering wheel, I did end up locking it up by the time I was done.
Tried nudging it back and forth, and even taking a pair of pliers and giving it a extra nudge, but no luck.
The thing is, its a new cylinder from RockAuto and I had used it for a few days after I replaced it so it was working fine, it has something to do with it sitting I believe.
It is cold here but no less than 30 at any time I would guess over the last month. I also have a leak in my windshield and the possibility that my step dad mentioned is possibly the water leaked in and froze it up, but I though that was a little far fetched cause I don't think it was leaking in that area anyway.
I feel like this should be somewhat common, but couldn't find anything in the search.
Thanks guys
Devin
Old Dec 23, 2012 | 07:44 PM
Gary Lewis's Avatar
Gary Lewis
Do you have a way of heating it up? It does sound like it may be frozen.
Old Dec 23, 2012 | 07:48 PM
ctubutis's Avatar
ctubutis
What can happen is the front tires are wanting to push on the mechanism through the steering gear when parked on a hill. But you say you can turn the wheel, so that rules that out.
The obvious... are you sure you're using the right key?
Old Dec 23, 2012 | 08:36 PM
dtgl90vt's Avatar
dtgl90vt
Same key I was using
I am going to jack the front up since I locked the steering wheel anyway, and then give it another try just by chance hopefully it will work.
If that doesn't work I am going to try heating it up with a hair dryer
Also I have another key I am going to try, mind you, I got two keys with the new cylinder, and the one I am using is one of the originals, I will try the other original tomorrow
Old Dec 23, 2012 | 10:11 PM
joshofalltrades's Avatar
joshofalltrades
remember to try flipping the key over and trying it that way too - sometimes keys aren't cut evenly on both sides and prefer one side over the other.
Old Dec 23, 2012 | 11:48 PM
LongRider's Avatar
LongRider
Or the pot-metal actuating-rod is binding in old cold gummed-up grimy-grease and will probably snap in two when it does give.
Old Dec 24, 2012 | 08:08 AM
dtgl90vt's Avatar
dtgl90vt
Yeah I tried flipping it, no luck, I believe when I first installed it too, I tried starting it both ways too check.
I thought the actuating rod didn't cause it to bind, but rather you could still turn the key but get no action
Devin
Old Dec 24, 2012 | 08:44 AM
Franklin2's Avatar
Franklin2
Take the short collar off around the column that is down near the dash. While you are trying to turn it, see if that rod on top is trying to move. Then get some pliers and grab the rod and while you are turning the key, help the rod forward and backward(it goes downward when the key turns) and see if you can get it undone. Right in that same area is where the tranny lever is locked in park if you have a automatic, so you can fiddle with the shifter also.
Old Dec 24, 2012 | 01:58 PM
dtgl90vt's Avatar
dtgl90vt
Im going to be making it there in another half hour or so, how do I remove the collar, is it a big process or not so much, I already have dash pad removed, and also the face plate for the cluster and such with the wood grain finish so I probably have some better visibility for what I am looking for
Old Dec 24, 2012 | 02:10 PM
ctubutis's Avatar
ctubutis
Phillips screwdriver is all you need IIRC, possibly also a trim panel at the bottom.
Old Dec 24, 2012 | 05:17 PM
dtgl90vt's Avatar
dtgl90vt
Trim panels already removed, I will get to evaluated it when I get there and see what I'm looking at, wasn't sure of the difficulty though, but if I can do it with a Philips it shouldn't be to bad
Old Dec 26, 2012 | 11:02 PM
dtgl90vt's Avatar
dtgl90vt
Got the collar off this morning and heated up above it with a hair dryer and got it moving again, came back again today and it was pretty rough again, although I never reinstalled the collar so maybe having no protection let it freeze back up, plus it wasn't protecting from the cluster and the dash board lying on it. Does anyone know if there is any thing I can grease up in the steering column near the steering wheel
Old Dec 27, 2012 | 09:11 AM
Franklin2's Avatar
Franklin2
We had a post the other day about this, and I commented that I sprayed wd40 down in and around where the key goes in, and it will work it's way down in the column and loosen up the old Ford grease. It seemed to help it for me and I didn't have to take it apart at the time, but like was mentioned by some other guys, taking it apart and cleaning it up and re-greasing would probably be the proper way.
I don't remember if the poster that had the problem in the other thread ever wrote back in or not and reported if he was successful.
Old Dec 27, 2012 | 11:46 AM
dtgl90vt's Avatar
dtgl90vt
Did you spray it into the tumbler itself ???
Or after taking the collar off did you spray up in there ( toward the steering wheel ) ?
Old Dec 27, 2012 | 06:43 PM
Franklin2's Avatar
Franklin2
I sprayed it into where the key goes, hoping it would run down into the mechanism. Spray it anywhere you think it will do some good, it won't hurt anything, it just makes a little bit of a mess so have a rag handy. Spray it, and keep working it back and forth.
Apprently you know how to take the cylinder in and out since you just replaced it, so why not take it out again and spray down in there?
jayro88
Apr 18, 2014 06:43 AM
davidw221
Nov 23, 2008 07:03 PM
10fords
Jul 21, 2007 03:01 PM
USMC_F250
Aug 14, 2006 08:00 PM
jon_1
Oct 25, 2000 12:42 PM
