my egt's
Old Dec 23, 2012 | 09:27 PM
turtlemann14's Avatar
turtlemann14
sent from gs, my probe was way to short to be used at the end of the manifold. i had to slide the little brass crush sleeve up very carefully to that the tip was in the middle of the pipe.
Old Dec 23, 2012 | 09:54 PM
1989f250IDI's Avatar
1989f250IDI
How did you do that?
Old Dec 23, 2012 | 09:55 PM
1989f250IDI
Originally Posted by '94IDITurbo7.3
you didn't cut the pyro lead wires at all did you?
No i didn't cut anything
Old Dec 23, 2012 | 11:31 PM
RacinNdrummin's Avatar
RacinNdrummin
My truck idles at 230-240, cruises 520 at 60mph flat ground... And on the top end, well needless to say, I can melt the bitch down...
Investment in a good EGT gauge is worth the money... Your engine can only tell you what your gauge is reading...
Old Dec 24, 2012 | 08:50 AM
Blind Driver's Avatar
Blind Driver
Originally Posted by 1989f250IDI
In the drivers side manifold. I used the glowshift clamp install instead of the tap and drill way
How deep does the sensor sit in the manifold? My Autometer sensor was almost deep enough to bottom out in the manifold.
Old Dec 24, 2012 | 09:25 AM
Otahyoni's Avatar
Otahyoni
It should be 1/3 to 1/2 into the pipe or manifold.
Old Dec 24, 2012 | 09:43 AM
turtlemann14
i just worked around it with a pari of pliers, if you hvae tightened it down, i am not sure if you will be able to move it(but i would still try a bit). you might go to a pluming sort and see if you can find a new crush and if you can VERY carefully cut the old one off so that you can slide it into the pipe.
Old Dec 26, 2012 | 02:12 PM
1989f250IDI
At idle i am 250-300 degrees and at 65 i am 525-575 degrees. I havnt hauled a load yet but ill be doing that later today.
Old Dec 26, 2012 | 03:54 PM
turtlemann14
were you just able to move the pyrometer in farther?
Old Dec 26, 2012 | 04:05 PM
1989f250IDI
Yes, it was not in far enough for an accurate reading. The clamp method glowshift sold me didn't allow it to go in very far. I should know the easy way isn't always the right way by now lol. When Ur lugging up a big hill and you hammer down she really builds up fast. I did that once on purpose since i didn't have a load on to see how high she would get. But judging from my numbers i got while driving i am completely healthy.
maribou912
Nov 28, 2011 11:07 AM
mrjones111
Jun 6, 2010 05:09 PM
yankeerebel
Oct 1, 2009 08:48 PM
ford4her
Sep 17, 2008 08:44 PM
nebechanezer
Mar 14, 2005 09:08 AM
