Cab light wiring?
Old Dec 23, 2012 | 03:00 PM
Cd4899's Avatar
Cd4899
Cab light wiring?
Could someone tell me where to connect my new Recon cab lights to? I pulled the side piece off of the dash and looked for an empty plug but didn't see any. Is there one in there somewhere? If so what does it look like and what color wires do I use?
Old Dec 23, 2012 | 05:09 PM
DRRXR's Avatar
DRRXR
Maybe this will help
RECON LED Cab Light Install with Pictures - Ford Truck Enthusiasts Forums
Old Dec 23, 2012 | 05:17 PM
Gunny77's Avatar
Gunny77
I ran my wiring down the passenger side pillar to the fuse box behind the kick panel at the passengers feet. I tapped into the running light fuse, this way they work along with the mirror lights.
Old Dec 27, 2012 | 11:49 AM
Cd4899's Avatar
Cd4899
Thank you but can I ask another question?...How do you connect to those mini fuses??? I was hoping that there was a plug in the dash somewhere that I could just splice a wire into it. I thought I saw somewhere where there was a plug on the drivers side that you could splice into? I don't mind using fuse #40 but how do you connect it to that small fuse???
Old Dec 27, 2012 | 12:39 PM
SavageNFS's Avatar
SavageNFS
You could use a fuse tap. Here are a couple of types...
You will find them at any automotive parts store.
Old Dec 27, 2012 | 01:07 PM
Hdslider's Avatar
Hdslider
If you want to connect to factory harness it is connector C-913 It is by e-brake assembly. way up there. it is grey. it has a tag on harness male harness 14A005 it is a 6 pin connector. 2 wires are missing on one side of connector, a BK-WH=ground, and a YE-GN hot for cab lights. I had wire pins so i put it as factory would be. you can just splice to those 2 wires and be done.
Old Dec 27, 2012 | 01:35 PM
Cd4899's Avatar
Cd4899
I don't see a 14A005. I do have a 14A413. Could that be it? It the only grey plug that I see up there.
Old Dec 27, 2012 | 01:36 PM
Cd4899's Avatar
Cd4899
Does it matter if its a cc and with different options?
Old Dec 27, 2012 | 02:12 PM
Hdslider's Avatar
Hdslider
No. Look for the female harness. Then 15A404 tags on harness now its way up there. Pull it down then its easy to work with. Obtw what year truck. As this is for 2011 dont know if they changed numbers on 12 or 13.
Old Dec 27, 2012 | 02:28 PM
Cd4899's Avatar
Cd4899
I don't see it. My truck is a 2012. I had the side panel off too and I just don't see that number anywhere. Gonna have to figure something else out. It's 25 degrees here so I'm gonna quit for today. Just too damn cold to be doing this outside. Lol. Thank you for the help though!
Old Dec 28, 2012 | 05:01 AM
Gunny77's Avatar
Gunny77
I used a low profile pigtail fuse from this company.
Accele Electronics 6710PT-10A Mini ATM Low Profile Pigtail Fuse, 10 AMP/ 12 pack | TESSCO
bcamill
Apr 6, 2018 06:57 AM
noshow
Aug 18, 2011 09:36 PM
BigBlueIron
Mar 19, 2008 06:59 AM
bob_351
Sep 5, 2007 10:11 PM
deisele75
Jun 23, 2006 02:18 PM
