Leaking seal?
Old Dec 23, 2012 | 01:03 PM
Specialtools's Avatar
Specialtools
Former Vendor
Originally Posted by Nicmike
I have all the special tools for that rear axle if you end up having to wait till the GTG in Yoakum.
What is that tool number- I may have extra set
Old Dec 23, 2012 | 01:09 PM
mueckster's Avatar
mueckster
Dana 80 seals ride directly on the axle. Sterling 10.5's are a "oil bath" two piece design with an integral wear sleeve.
Genuine Motorcraft BRS 51 BRS51 Seal | eBay
Old Dec 23, 2012 | 01:20 PM
mueckster's Avatar
mueckster
Ford # 205-448 Axle Nut Socket
I have this one. O'Reilly sells them. Performance Tool W83008.... $16.99
Old Dec 23, 2012 | 04:30 PM
jeffreyt's Avatar
jeffreyt
Got the new seal in, but when I torqued down to 60 ft-lbs, it looks like it hasn't seated all the way onto the spindle. Any thoughts?
Old Dec 23, 2012 | 04:34 PM
jeffreyt's Avatar
jeffreyt
I'm gonna be a little upset if he gave me the wrong seal...
Old Dec 23, 2012 | 04:37 PM
AzPete's Avatar
AzPete
Did you trial fit the seal in the housing first?
Old Dec 23, 2012 | 04:38 PM
jeffreyt's Avatar
jeffreyt
Can anyone confirm national seal no. 370247A? That's what I have.
Old Dec 23, 2012 | 04:40 PM
jeffreyt's Avatar
jeffreyt
Fit like a glove inside the hub, just doesn't want to seat onto the spindle.
Old Dec 23, 2012 | 04:57 PM
JWC 3's Avatar
JWC 3
I have seen a few rear ends that had a factory installed wear sleeve and after market seals would not fit . Cross reference your factory seal # to be sure . I have also seen axle repairs done that take a special seal after .
Old Dec 23, 2012 | 04:58 PM
jeffreyt's Avatar
jeffreyt
Never mind, I'm stupid. Part of the old seal is still on the spindle.
Old Dec 23, 2012 | 04:59 PM
jeffreyt's Avatar
jeffreyt
Or maybe it's the wear sleeve you're talking about...
Old Dec 23, 2012 | 05:07 PM
AzPete's Avatar
AzPete
Hmmmmm.....words that will haunt you forever once posted on line...lol.
Glad you sorted it out.
Old Dec 23, 2012 | 05:22 PM
  #28
JWC 3's Avatar
JWC 3
Yep , looks like part of the old seal , OOps ! Stuff happens .
Old Dec 23, 2012 | 09:46 PM
  #29
mueckster's Avatar
mueckster
Yes, that is the correct seal which has the integral wear sleeve, also.
Yes, it is part of the old seal.
Yes, it is a wear sleeve that has to be removed before the new seal can go on correctly.
You got it figured out. Hope you didn't damage the new seal when you torqued it down against the wear sleeve.
Old Dec 23, 2012 | 10:20 PM
  #30
timmyboy76's Avatar
timmyboy76
Got my new/spare seal on the shelf as well, Roland. Mt p/s blew out during summer. Jeff, i learmed after the fact, but if/when i have to do the d/s seal, i'm gonna fill the cavity with diff fluid then bolt up the axle OR park truck with p/s tires in the gutter overnight, for bearing cavity to fill with oil.
I wasnt too stoked in packing the bearings with grease just for it to contaminate the diff fluid?
