Good catch on ebp that was v not psi. Rechech on that is ebp koeo13.8, at idle 17.4 at 2500 rpm went to 34.3 psi. On way to work as power would stumble seemed to have more white smoke then tranny would shift andit cleared up. Thanks again for any help seems like a ficm repair soon
Changed out EBP sensor and ran hard bendable plastic down tube, all clear.
Re do on the tests ICP koeo .0, idle 678 2500rpm 1425
ICPv 0.24, 0.97, 1.59/ IPR 14.84, 27.73, 42.97/
BARO 13.67, 13.67, 13.67
EBP 13.8, 16.3, 26.7
MAP 13.70, 13.77, 18.03
FICMmp 47.5 TO 48.0, 48.0, 48.0
VOLTS 12.3, 13.56, 13.56
At high idle running rough didn't want to be there kindof cutting out but not really. did not have much white smoke, think i am gonna do a bubble test and see if injectors are problem. Any thoughts on the ficm?? Get new EBP tomorrow too.
Alright i will look at the tstat, has been running unusually cool, barely above lower line on gauge. Havn't cleaned EGR in a while will attack that too.
cleaned the EGR yesteerday and seemed stuck closed. no improvement from that, did get more white smoke from the exhaust and seemed more sluggish when making my drive.
1- now what?
2- FICM never seems to go below 47.5 and usually at 48.5. Could it still be bad?
3- Also noticed some light oiling ontop of oil filter cover- no obvious source I can see.
