What wheel size fits my hub??
Ok so your are looking for wheels to fit your hubcaps? based on what I am seeing on your album pics.
Your truck with the red wheels? that is an F1 (5 lug nuts )1/2 ton axle.
The hubcaps we helped you with, are for an F2/F3 so I remember...NumberDummy mentioned..F2/F3 wheels are 8 lug 3/4 ton.
so if thats the case, your hubcaps are not going to ever fit your truck.
You need to sell your hubcaps and move on to a different hubcap and or wheel combination.
6A-1130 .. FORD block letter (on rectangular raised center section) "Innie" Hubcap ~ Reproduced (pictured in Carpenters 1948/56 truck catalog).
1948/52 F1 and late 1947 & 1948 Ford Passenger Cars. Used as a replacement for BAAA-1130-A hubcap that is not repro'd for 1953/56 F100's.
Innie: So called because the hubcap snaps onto tabs located on the inside of the wheels center section.
Innie wheels/hubcaps used thru 1964 and on some 1965/66's.
First year for "outie" wheels/hubcaps: 1965 F100 (outies used thru 1996). Innies were also available in 1965/66.
Outie: So called because the hubcaps snaps over raised tabs located on the outside of the wheels center section.
21A-1130: -Ford- (Ford script within oval hubcap): 1942 Ford Passenger Cars.
11A-1130: Ford in script hubcap with two raised shoulders: 1941 Ford Passenger Cars.
59A-1130: FORD block letters with three red diagonal lines above/below FORD: 1946, early 1947 Ford Passenger Cars.
Dgrant51
01-02-2015 05:14 PM
