Trans E40D
Old Dec 20, 2012 | 01:56 PM
animal_in_nm's Avatar
animal_in_nm
Trans E40D
I bought a F350 box van with a E40D trains, It dies when I shift it in to drive,or revers. If you shift and step on it like your racing it drive ok but with a learch. Can any one help?
Old Dec 20, 2012 | 03:14 PM
Lazy K's Avatar
Lazy K
Sounds like the torque converter clutch (TCC) is not unlocking. May be a bad TCC (need new converter), may be defective wiring, may be that the internal fluid filter has fallen into the pan (drop pan and look).
Probably a good idea to check for trouble codes, even if no light on.
Good luck.
Old Dec 21, 2012 | 10:59 AM
animal_in_nm
Thank you, I saw something on the TCC wiring to turn off the TCC, If I do this will it hurt the trainny?
Old Dec 21, 2012 | 09:48 PM
impish's Avatar
impish
If the Torque Converter Clutch is itself at fault, stuck in engaged position, turning off the power to it's solenoid will do no good. The solenoid must be operable to turn off (or on) the clutch whether done manually or by computer.
To answer your question, no, the transmission can be used forever with the clutch disabled or turned off. However, if the clutch is locked in the engaged position, as soon as the transmission is shifted into gear, it will kill the engine.
impish
Old Dec 22, 2012 | 07:17 AM
subford's Avatar
subford
Dough that it is the transmission.
If you give some throttle and it learches and it is still running standing still you may have a bad IAC valve.
Yes it will shorten the life of the transmission if the the TC never locks as the transmission will run at a higher temp and heat is what kills the E4OD.
Old Dec 22, 2012 | 08:29 AM
Blown349's Avatar
Blown349
Always, First, pull codes to see what is wrong. It will likely tell you. Most auto parts stores will do it for you, purchase a code reader or do it yourself: Fuel Injection Technical Library » How To Run a Self-Test
Do you have a good solid idle?
If it is missing and idling slow it's going to die when put in gear. Idle fixes include cleaning the throttle body, checking/cleaning the IAC Idle Air Control, checking the TPS Throttle Position Sensor, and then setting the idle.
Old Dec 22, 2012 | 09:00 AM
animal_in_nm
I did put a code reader on it. It said system pass. I can't find anything in the book about that eather.
Old Dec 23, 2012 | 11:06 AM
Blown349's Avatar
Blown349
No codes? OK that points more to poor idle quality and you didn't answer that question. I mean if it's idling poorly and you drop it into gear it's going to die.
Old Dec 23, 2012 | 04:05 PM
animal_in_nm
Idle good tile you drop it in drive,then dies.
Old Dec 24, 2012 | 01:26 PM
Lazy K's Avatar
Lazy K
My guess would be a cracked TCC hub but only a guess. If it is that you would need to replace the converter.
However subford is rarely wrong so check out engine (IAC valve, base timing, etc.).
Good luck.
Old Dec 24, 2012 | 03:44 PM
Lead Head's Avatar
Lead Head
When you're driving, does it come to a stop in gear fine?
Old Dec 25, 2012 | 01:37 AM
jccapri's Avatar
jccapri
2001 f350 4x4 i have the same problem when putting into gear or coming to a stop the truck will idol fine and then it will start to lunge forward and try to die. The OD light was flashing the day before it started to choke down
Old Jan 1, 2013 | 09:59 PM
bigdaddy4793's Avatar
bigdaddy4793
You may want to check your brake lights as well. Try driving in high gear, when up to speed ride the brake. The engine should speed up as the tcc disengages.
Old Jan 10, 2013 | 04:09 PM
animal_in_nm
checked codes again new code says ECT out off limits. can you tell me what and where it is?
Old Jan 11, 2013 | 12:32 PM
nebechanezer's Avatar
nebechanezer
Engine coolant temperature. Just means it wasnt at operating temp when you checked codes.
