Upper castle nut gone!!!
Old Dec 20, 2012 | 01:39 PM
ROBBINthaHOOD's Avatar
ROBBINthaHOOD
After driving the Ex this morning to take the kiddos to school I noticed it was slightly pulling to the right. Decided to jack it up to check for slack since Ive had the clunking noise and I had ALOT of upper play back and forth so removed the wheel and the castle nut and most the threaded stem part were gone, but ball joint looks to be seated still so wonder if during the wreck a few months back that it might have cracked it but the initial line up we had didnt catch it and then driving it almost daily stressed it enough to break on off. Anyway looks like I get to take the day off to replace the upper joint, thinking maybe should replace lower also but it looks to be in good shape.
Old Dec 20, 2012 | 02:25 PM
EXv10's Avatar
EXv10
I wouldn't touch the lower one.
I had my lower joints done a while back and they left 2 of the 4 bolts out of the knuckle to hub (4wd) which I didn't see until a year later plus they wanted $25 more for replacing some 50 cent clips in the pads and then didn't give me a receipt..............didn't go for any of it and too late on the bolts to say anything since they were 1000 miles away.
Old Dec 20, 2012 | 02:31 PM
ROBBINthaHOOD
I think I will just stick with the upper, from the looks of it appears to be easier to change. Got a choice between napa, autozone and oreilly for parts locally.
Old Dec 20, 2012 | 03:29 PM
ROBBINthaHOOD
Upon further inspection it appears the ball joint is fine but the camber/caster adjustment bushing is gone.
Old Dec 20, 2012 | 05:39 PM
ROBBINthaHOOD
Did not know which degree bushing to get so went with the 1 degree, got it set in and clamped down, Ex is tracking straight again with no front end clunk. Ill have to take it in to get the alignment checked again since I know I dont have it spot on and may have to replace the bushing with a different one but atleast we are now safe again.
Old Dec 20, 2012 | 06:30 PM
Tom's Avatar
Tom
While I see Brent's point I don't agree. Balljoints aren't uncommon parts to fail, and if I'm going through the effort and expense to replace the upper I would also do the lower. Remember that you have to replace some of the seals in the knuckle to do this job, so why go through the expense again when you could do both with just a few more minutes?
I would also recommend a quality name brand part rather than a parts store brand.
www.rockauto.com FTW!
Old Dec 20, 2012 | 10:14 PM
EXv10's Avatar
EXv10
It gets back to my motto, if it ain't broke don't fix it. I learned when I was a mechanic you are actually better off NOT fixing things that don't really need it. The less you touch to better off you are and other mechanics share the same feeling. It is a lot harder to replace the bottom at the same time...........not needed. I see so much unnecessary fixing and money spending in here and I don't know whether to laugh or cringe.
Old Dec 21, 2012 | 01:32 AM
ROBBINthaHOOD
All I done was bought and installed the missing camber bushing so no other work was done. There is a little play side to side and back and forth but not much, dont know how much is acceptable but Ive put around 50 miles on her since I installed the bushing and it is tracking straight as an arrow. I am going to do all the brakes one day next week but thats about the extent of the work I intend to do. I think I got lucky today without having to do anything to the ball joints.
ravens fan
1997 - 2003 F150
Sep 19, 2013 01:20 PM
jeter
Jan 6, 2006 04:03 PM
DYI
1997 - 2003 F150
Apr 16, 2005 08:21 AM
Gooeyny
Aerostar
Dec 20, 2004 06:01 PM
andym
1978 - 1996 Big Bronco
Oct 16, 2003 07:26 PM
