Brakes and ball joint questions.
Lately on our 01 Limited V10 2wd, the brakes have been squeeling pretty good and the last couple of days right after taking off from the driveway and pressing the brakes there is a clunk sound coming from the front and you can feel it under your feet, only does it during slow braking that I have noticed. Anyway fixing to be off for about 12 days for the holidays so ordered a set of rotors and pads for all corners. Done more reading about similar symptoms and some suggested ball joints. Now we just had an alignment done after our wreck first of July and shop said alignment and ball joints were good. I haven't jacked it up since to check for slack as she steers straight as an arrow even under braking. But in case I do have to do the joints since ill be half way into it anyway, what are the 2wd part #s, I went on amazon with the K80028 and K80027 and it said it wasn't compatible with my model. Want to double check before I get the wrong thing if I do have to buy a set. Thanks.
RedDawg
1999 to 2016 Super Duty
02-18-2008 08:24 PM
ChargerFan
10-12-2004 12:02 PM
brittfan
02-23-2004 04:08 PM
