lund sun visor install?
Old Dec 19, 2012 | 06:33 PM
94mustanggtfast's Avatar
94mustanggtfast
i just got a used lund sun visor. what do i need to install it?
Old Dec 19, 2012 | 06:38 PM
Puddy's Avatar
Puddy
im gonna be brutaly honest with you.... you dont want to do it.
Unless you like Roof Rot.
Old Dec 19, 2012 | 06:45 PM
Midnite1987's Avatar
Midnite1987
I lined mine up pre drilled the holes. Hit each hole with a squirt of primer. Once dry put a good amount of silicone around the hole and re installed the visor so the silicone made a seal to protect from water entering cab.
Old Dec 19, 2012 | 06:52 PM
Puddy's Avatar
Puddy
just gonna throw this in here
Old Dec 19, 2012 | 08:37 PM
GNR22's Avatar
GNR22
Just take a few self tapping screws to it. It's not going to kill it. I do the exact same thing that Midnite 1987 does. When people put them on and don't do anything to it in the form of protecting the bare metal, then you end up with a rotten roof like Puddy warned against.
Old Dec 19, 2012 | 08:44 PM
Diesel_Brad's Avatar
Diesel_Brad
Rot is NOT an issue if done correctly. I have been installing them for the past 20 years and YET to have a rust issue.
What i do is TAPE the visor in place and look it over real good making sure it is centered and not too high or too low.
Take a sharpie and mark all 8 holes.
Remove visor
Drill all 8 holes with 1/8" drill bit AND BLOW ALL METAL SHAVINGS OFF
Put dab of silicone on all 8 holes
Tape visor back in place.
COVER screw threads with silicone and install screws LOOSLY one at a time.
When you have them all in, GENTLY tighten them. Remember you are threading into sheet metal so dont get carried away. Wipe excess silicone off of visor and roof
Doing this will guarantee MANY years of RUST FREE/LEAK FREE years
Old Dec 19, 2012 | 09:10 PM
Puddy's Avatar
Puddy
I use to paint for a living remember...
Old Dec 19, 2012 | 09:12 PM
Puddy's Avatar
Puddy
I suppose it depends where you live as well. Anything in the rust belt isn't that smart of you want to keep your truck relatively rust free
Old Dec 19, 2012 | 09:15 PM
Diesel_Brad
I understand Purdy and I have seen quit a few issues with rust from visor installs(all done incorrectly)
Old Dec 19, 2012 | 10:14 PM
fordka's Avatar
fordka
well looks like my roof is gonna be leaking in a few yrs then. idc i love the look too much to loose my visor and i havnt had a problem yet.
Old Dec 20, 2012 | 10:50 AM
94mustanggtfast
what kind of screws do i need to use? i know that they dont need to be that long so the shortest i can find?
Old Dec 20, 2012 | 04:47 PM
Diesel_Brad
1" x 1/4" get STAINLESS
Old Dec 20, 2012 | 09:52 PM
deljac's Avatar
deljac
I pre drill a small hole and then use self tapping screws. And then back out the screw and silicone it and put the screw back in. I did that to my 95 when i bought it new and when i pulled the visor off last year when my truck was wrecked there wad no rust, and i live in the rust belt
Old Sep 8, 2024 | 11:05 AM
Whydowelikefords's Avatar
Whydowelikefords
4th Gear
I didn’t use self tappers for mine I lined it up marked the holes and put rivet nuts in there so they have better hold then self tappers and the I just used dummy tape over everything for a seal and I took my truck to the car wash the next day and I didn’t notice any leaks
Old Sep 10, 2024 | 01:15 PM
DowneyB's Avatar
DowneyB
I lined it up with tape and marked all the holes, then drilled them with a stepper bit and used rivet nuts on mine. Stainless nuts, and stainless screws to go with. I also put a dab of silicon on the rivet nut before I put it in, and a bit on the screw as well. I have not had any issues with leaks or anything coming loose.
charles adams
Mar 22, 2019 11:17 AM
ktgovols
Nov 18, 2016 10:12 AM
79finally
2009 - 2014 F150
Oct 18, 2016 09:42 PM
FireBlue
Jul 9, 2010 01:13 PM
mcjones44us
Mar 5, 2008 07:02 PM
