Expedition export modell with lockers?
Old Dec 19, 2012 | 11:59 AM
Robin K's Avatar
Robin K
Hello,
I think about buying an Expedition from 2003, about 100k mileage.
5.4 liters, 224 kW, Eddie Bauer Edition. (canada edition)
The seller keeps writing and telling me that for sure he/it has lockers at the front ant rear axle.
He's a private person and from his grammar he does not to be thaaaaat clever :-)
Unfortunately I'm also not a mechanic and not a Ford specialist, either.
All information I found gave the information that it was possible to order the EB Modells with Limited Slip Differentials, but I think they would not be 100% lockers, would they?
That guy tells that his EB has 2wd and 4wd mode PLUS two reduction modes , could someone please confirm his information? Or tell me, what to tell him to figure that out? (I think about something like a modell code or something similar)
He lives about 4 hrs driving away so I'd like to know as much as possible before sitting 8 hrs in my car just to figure out that he was wrong.
Thank you in advance
Old Dec 19, 2012 | 05:13 PM
Moto Mel's Avatar
Moto Mel
The "Traction Lock" unit is the only one Ford has offered as OEM. The dealers will often sell and install any type of locker the customer wants, usually after he takes delivery of the truck. A locking front differential has not been offered in my recent memory.
Old Dec 19, 2012 | 05:56 PM
alwaysfords41's Avatar
alwaysfords41
The selector is 2WD, A4WD, 4H and 4L. A4WD is a sensing mode that kicks to 4H when wheel slip is detected and stays engaged until the slip is gone.
Old Dec 20, 2012 | 02:14 AM
Robin K's Avatar
Robin K
Is the "traction lock " a real lock then?
Additionally wikipedia.EN is giving some information about a "Four-wheel electronic traction control was now available as an option, and simulated front and rear differential locks"
What is that and what is that doing? The same like mercedes? Braking the spinning wheel? Ford Expedition 2nd Gen Wiki
Anyways, thanks for the explanations to the selector. that was also helpful
Old Dec 20, 2012 | 02:39 AM
Moto Mel's Avatar
Moto Mel
Traction Control is not the same as a "Traction Lock". The traction Lock differential is Ford's name for a locking or limited slip differential that is very similar to GM's Positraction in that they both use clutch packs to lock the axles into the same speed when power is applied. The earlier true locking type of differential is a mechanical type of operating system that uses a cam and ramp design sold as "Detroit Locker" products. They are very effective but pretty noisey for a non race type of vehicle. There are also Air Lockers, Electric Lockers and probably many that I have never heard of. Just be careful of a welded spider gear locker A/K/A a "Lincoln Locker" as that will cost a ton to reverse and can cause problems for the inexperienced driver in any adverse conditions.
I don't have any experience with the "Traction Control" systems so I'll not comment on it, there are several on the forum that can make informed statements on it.
CWCW
Apr 16, 2018 05:47 PM
V8muscle
Dec 19, 2010 04:11 PM
operator exmark
Jul 24, 2007 07:21 PM
pimpin78
Apr 20, 2004 10:43 PM
Ben242
1978 - 1996 Big Bronco
Oct 27, 2003 06:40 PM
