Locking tail gate
Locking tail gate
Ok I started yesterday looking into a way to slow down the thieves stealing tailgates. So what I found was there are three manufactures that make a lock that goes around the hinge. ok but cheesy. I found another company (Pace Edwards) that makes an actuator that ties into your your electric locks and works off the factory locks. I Have ordered one off the internet for $66 after shipping that is fairly simple to install. There are others that made their own for a little less money. Anybody installed one?
It works so when you lock your doors it also locks the tailgate. something these trucks should already come with. If the theif bust the lock then yes im pretty sure they can still take it. I havent seen a tailgate lock busted though. They just open them up and take them off the truck most of the time.
Mine stays locked when not in use. Some people have wrapped a hose clamp around the right side pivot point on the tail gate. The right side is the side that is lifted out so the left side can be removed, IIRC. The hose clamp may not stop a theft but it'll slow em down or even discourage them.
The hose clamp, which is adjustable, works fine. I've had one on each truck I owned. You simply put it on the right side pivot point of the tailgate, insert it and screw it tight. Like one of the posts says above, it is not infalliable, but I don't think anyone is going to take the time to unscrew it if they want to steal the tailgate............
