rocker shafts
Old Dec 18, 2012 | 09:10 PM
cws10190's Avatar
cws10190
rocker shafts
i was wondering if there is an issue with using harlond sharp roller rockers on sealed power non roller rocker shafts, ill be using pop spacers, stands, and end supports. here is the cam from lunati. they said it would be a 562/574 with 1.76 rockers
edel heads
Advertised Duration (Int/Exh): 268/276
Duration @ .050 (Int/Exh): 227/233
Gross Valve Lift (Int/Exh): .552/.564
LSA/ICL: 110/106
Valve Lash (Int/Exh): Hyd/Hyd
RPM Range: 1600-5800
Old Dec 18, 2012 | 11:38 PM
7636074460's Avatar
7636074460
I bought Barry rabotniks book and from what I understand the sealed power shafts and factory shafts should hold up to quite a bit with the added end stands. Unless its a race motor with 10:1 compression and stupid big cam youll be fine.
outcrydrummer
Jan 2, 2014 04:46 PM
theguy_88
Feb 26, 2006 04:30 PM
grif95
Feb 3, 2003 09:46 AM
bigblockhead
Mar 18, 2000 08:56 PM
