bad ball joint warning signs?
Over the last year my Bronco (1995 Bronco 5.0 E40d) has been in the shop twice for some minor repairs I couldn't tackle myself, and both times the mechanic gave me a spiel about my driver's balljoint going bad. The first time was back in August, and most recently March. Now, the truck rides fine (aside from the fact that it needs shocks badly), with no vibrations, tracks straight on the highway, doesn't pull when braking, etc. So, exactly what are the warning sighns of a ball joint going bad? I would think you'd see vibrations, bad tire wear, maybe something like bad tracking at speed, but I don't have any of these problems. I haven't had the time to jack up the truck and try and move the wheel by hand back and forth like I've heard to do, but that's cause my apartment complex has some asinine rules. So, is he just looking for my hardearned cash or is he telling the truth? There's other things I'd like to spend my dough on besides new balljoints.
yo,
symptoms are what you basically described that is not happening to your B: clunks over bumps and esp when you begin to move from a stopped position; uneven tire wear..some symptoms such as "play" in all directions when checking arealso caused by bad wheel bearings.
Had both uppers go in my '92. Caused terrible sawtoothing of the outer edge of the tread and wore the inner edge down at twice the rate of the rest of the tire. Basically it causes a negative camber situation. Allows the tires to rest heavily on the inner edges. If you could imagine angling the front wheels so that they sat like this... / ----- \ instead of like this... l ----- l, as you look at the truck from the front. Bad ball joints and/or wheel bearings and even badly worn axle pivot bushings will cause this.
I went ahead and had all four replaced on mine just because I didn't feel like having to tear that much of the front end apart again any time soon. The whole thing cost me $350 for the removal and installation of old and new ball joints. I had to bring them the steering knuckles. Personally I think I got hosed after doing a bit more research. Just my experience.
1972fordhighboy2
02-23-2017 09:06 PM
Racerguy
1997 - 2003 F150
212
09-14-2016 06:14 PM
sunogbahay
19
03-18-2011 01:49 PM
flcobra
16
11-04-2008 09:08 PM
