Power Steering Question
Old Dec 17, 2012 | 09:16 PM
Mercmeister's Avatar
Mercmeister
Greetings!
I am in the process of installing power steering in my '66 Ford F100 using parts from a '69 Ford F100. It will have a 300 cid Ford straight six engine. The steering column and power steering box are from the '69. My question is which pitman arm do I use? The '66 or '69?
Thank You,
Dan M.
Old Dec 17, 2012 | 10:24 PM
SuperSabre's Avatar
SuperSabre
I'd use the pitman arm from the donor truck that's providing the power steering components. When I did my conversion, my "new" (junkyard) pitman arm actually had "power steering" - or some abbreviation of it - stamped on it.
Old Dec 20, 2012 | 09:23 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Which 1969 F100 P/S gearbox are you using, Bendix or Ford? The P/S Pitman Arms are not the same.
Bendix P/S: 1966/68 F100/250 2WD, 1969 F100/250 2WD before serial number D96,001.
Ford P/S: 1969 F100/250 2WD & F350 from serial number D96,001.
Old Dec 20, 2012 | 10:50 AM
Mercmeister
Good Morning, ND -
The '69 power steering box is a Saginaw/Ford unit, not a Bendix. I have the '69 pitman arm as well as the '66 pitman arm from the manual steering box. I need to replace the '66 drag link and steering linkage since it is worn out. From the minimal reasearch I've done, it sounds like if I use a '69 drag link and '69 steering linkage connected to the '69 power steering box and '66 I-Beam, I should be okay. Just looking for some expert advice before I spend the money on a new drag link.
While on the subject, O'Reilly's lists two different brands of drag link - one is a MOOG for $140.00+ and the other is an off brand for less than half as much. Any advice on this subject will be greatly appreciated.
Thank You!
Dan M.
sonny1965
WTB - Parts & other
Nov 28, 2016 03:13 PM
Roger C
Oct 20, 2014 12:10 PM
pcta12
Sep 11, 2006 12:57 PM
dotcentral
Aug 26, 2005 07:14 AM
