2003 Explorer issues
Old Dec 17, 2012 | 11:21 AM
fearfactory's Avatar
fearfactory
I have a 2003 Explorer 4.0l 4x4 auto. Yesterday day the passenger rear tire got a flat, so I put the full size spare on, and went about my business. About 2 miles up the road is a stop sign, so I start slowing down, and while slowing down I can hear a whining thumping sound from the front of the vehicle. It wasn't doing this before the flat, but right after I put the spare on it starts to do this. It only happens when slowing down, not under acceleration. Thanks for any ideas
Old Dec 17, 2012 | 12:45 PM
shorod's Avatar
shorod
Does it also make the noise when coasting to a stop, or only when applying the brakes? Is there any pulsation in the brake pedal or steering wheel when braking? Have you confirmed the lugnuts are properly torqued?
-Rod
Old Dec 17, 2012 | 02:07 PM
aquanaut20's Avatar
aquanaut20
Changing a REAR tire should have no affect on the front axle, unless you have ControlTrac. In which case, a tire of different circumference may activate the front axle (4x4)... Philip
Old Dec 17, 2012 | 02:17 PM
khadma's Avatar
khadma
Carpenter Local 745
I concur......
You would think the engineers would design for such things.
Old Dec 17, 2012 | 09:05 PM
fearfactory
The whining and thumping noise only happens when I coast to a stop. Im now thinking its the difference in tire size, since the spare has new tread, while the other 3 tires have about worn out tread. The more I think about it, the spare is whats causing this issue, since it started making the noises the second I put the spare tire on.
Old Dec 18, 2012 | 06:21 AM
2002sport's Avatar
2002sport
Yeah, get the old tire fixed and try that and see if the noise goes away.
Old Dec 18, 2012 | 06:28 AM
shorod's Avatar
shorod
Or, better yet, replace all four tires (including the flat) since you mention the primary tires are worn out anyway. The snow's coming, be safe for yourself and others on the road!
-Rod
patrickmcl
Apr 29, 2013 06:51 AM
RunNRhino
Sep 26, 2009 02:09 PM
topo4u2
Oct 13, 2002 12:21 PM
drjohn99
Oct 11, 2000 08:22 PM
