Is the fuel return line to the filter necessary or can I remove it?
Received 3,148 Likes
on
on
look for short peace of hose near frame rail drivers side in return line mine was cracked and leaking... i vote to keep return lines stock as i beleave the fuel that exits the injectors and returns carrys heat away ??? I relaced evey inch of return lines leaking or not...to be shure....starts right up ...the wait light comes on.. I stomp the pedle to set advance and idle and turn the key...
I was hoping someone would post the official Ford fix, but there's more than one way to skin a cat and this is how I did it:
1. Clean around the fuel return line hose fitting on the filter housing.
2. Disconnect the return hose from the fitting on th filter housing.
3. Remove the hose fitting from the housing. There is a spring and steel ball inside, the valve that doesn't work - I removed the spring but didn't bother trying to get the ball out, it will do no harm.
4, Install a tapered brass plug in place of the hose fitting. I think it's a 1/8 in BSP, plug, the thread measures 3/8 in at the widest point and has a 1/2 in hex head,( I just happened to have one that fitted). I used PTFE tape on the threads to make sure it's air tight.
5. Cut the return hose off about 1 or 1.5 in from injector #1.
6. Plug this hose stub with a short piece of metal rod and clamp it either with the now spare spring clip or a regular hose clamp, I think 1/4 in diameter rod would work, I only had 5/16 in and it was too large really.
7. Bleed the air from the filter by depressing the pin on the Schrader valve on the filter housing and have someone crank the engine (thanks Ford!) no more than 20 seconds at a time with 2 minute cooling off pauses between cranks, until fuel flows without bubbles. Some thoughtful person installed a second filter on my system in line before the fuel pump and original filter and it has a manual priming pump.
If you still get air in the system after this modification, maybe you've got bad olives! See this thread: https://www.ford-trucks.com/forums/1...m-upgrade.html
If you would like pics I can take some, but I hope the above tells all, just let me know.
BTW does anyone have an answer to my question posted above regarding the return line connection to the top of the injection pump?
on
ctann
10-26-2009 06:57 PM
jooknon
06-22-2009 02:19 PM
2New2Fords
09-29-2006 05:54 PM
