o2 sensor question
Old Dec 16, 2012 | 12:41 AM
300-six's Avatar
300-six
o2 sensor question
ok i have a 93 f150 with the 300 6 i have an air fuel ratio guage that i would like to install but i dont know which wire is the signal wire on my o2 sensor it is a 4 wire sensor does anyone have a wiring diagram handy for me or know off hand which one i need to be splicing into
Old Dec 16, 2012 | 09:20 AM
jrwhitmire's Avatar
jrwhitmire
You need to buy a wide-band oxy sensor and a weld on bung, and weld it onto your exhaust. The stock narrow-band wont work for your guage, but you need to retain it for closed-loop operation.
Old Dec 16, 2012 | 11:38 AM
300-six's Avatar
300-six
oh ok is there a certain brand that i need to look for thanks for the advice
Old Dec 16, 2012 | 12:05 PM
Conanski's Avatar
Conanski
What brand and style gauge do you have? Does it just have a series of LEDs that are labeled rich to lean or does it have an actual numerical scale with numbers from about 10-18? If it's just the rich/lean gauge then it can be tapped into the factory sensor but it'll just swing back an forth like in the link below most of the time when the system is in closed loop, and it will peg at rich when you have the pedal floored and the computer switches to open loop. Air Fuel Gauges - Auto Meter Tech Tips
This is fine of course it will show you that the EFI system is operating normally, but it won't tell you the actual A/F ratio the system is running at, to get that you need a wideband O2 and gauge installed in it's own bung in the exhaust. One of these systems will run $200 to $300 and options include..
Digital Wideband Air/Fuel Gauge - Wideband O2 UEGO, Water/Methanol, Stand Alone Engine Management, Piggyback F/IC, Tru Boost Controller, Gauges, Automotive Performance Electronics
Innovate Motor Sports On-Line Store
Old Dec 16, 2012 | 12:11 PM
300-six's Avatar
300-six
yes i have one that is just labeled lean to rich with leds so if i can use the factory sensor which wire would i need to tap into
RIKIL
May 21, 2012 10:10 PM
mauicruza
Computer Chips & Tuners
Mar 1, 2011 10:55 AM
93_flareside
Aug 27, 2010 04:36 PM
Ranger GT2
Electrical Systems/Wiring
Nov 23, 2009 04:12 PM
PigFarmer
Oct 11, 2002 08:53 PM
