Btw, from what I have read, the ficm isolators were not used on our MY trucks, only have rubber isolators under the bracket that the ficm is mounted to, in other words the rubber should only be down by the valve cover where the bracket meets the engine, not right under the ficm
There are parts I found ,after I removed mine, I paid 50 for the rubber and steel sleeves, the factory bolts and nuts on studs would not make it through them without utilizing a set of vise grips, then I wised up.
