Torque App O2 Test
Is anyone familiar with the O2 test on the torque android app? It says I failed some of them but I have no idea what they mean. I'll post the results below. Thanks in advance for any help.
Mode $06 report generated by Torque for Android ==============================<wbr>=============== === Vehicle VIN: ---------------------- Vehicle Manufacturer: Ford Vehicle Calibration ID: ------------ Test report: ------------------ MID:$01 TID:$01 Rich to Lean sensor threshold voltage(constant) - O2 Bank 1 Sensor 1 Max: 7.99527V Min: 0V Test result value: 0.44994V PASS ---- MID:$01 TID:$80 - O2 Bank 1 Sensor 1 Max: 7.99527V Min: 0.45994V Test result value: 0.72029V PASS ---- MID:$01 TID:$81 - O2 Bank 1 Sensor 1 Max: 3A Min: 0.23A Test result value: 0.473A PASS ---- MID:$02 TID:$01 Rich to Lean sensor threshold voltage(constant) - O2 Bank 1 Sensor 2 Max: 7.99527V Min: 0V Test result value: 0.44994V PASS ---- MID:$02 TID:$81 - O2 Bank 1 Sensor 2 Max: 3A Min: 0.23A Test result value: 0.495A PASS ---- MID:$05 TID:$01 Rich to Lean sensor threshold voltage(constant) - O2 Bank 2 Sensor 1 Max: 7.99527V Min: 0V Test result value: 0.44994V PASS ---- MID:$05 TID:$80 - O2 Bank 2 Sensor 1 Max: 7.99527V Min: 0.45994V Test result value: 0.70309V PASS ---- MID:$05 TID:$81 - O2 Bank 2 Sensor 1 Max: 3A Min: 0.23A Test result value: 0.469A PASS ---- MID:$06 TID:$01 Rich to Lean sensor threshold voltage(constant) - O2 Bank 2 Sensor 2 Max: 7.99527V Min: 0V Test result value: 0.44994V PASS ---- MID:$06 TID:$81 - O2 Bank 2 Sensor 2 Max: 3A Min: 0.23A Test result value: 0.473A PASS ---- MID:$21 TID:$80 - Catalyst Monitor Bank 1 Max: 0.49999Ratio Min: 0Ratio Test result value: 0.04297Ratio PASS ---- MID:$22 TID:$80 - Catalyst Monitor Bank 2 Max: 0.49999Ratio Min: 0Ratio Test result value: 0.05078Ratio PASS ---- MID:$30 TID:$eb - Max: -81.63% Min: 225.44% Test result value: -0.16% FAIL ---- MID:$3a TID:$80 - EVAP Monitor (cap off) Test incomplete or dependant test failed -- MID:$3a TID:$81 - EVAP Monitor (cap off) Test incomplete or dependant test failed -- MID:$3a TID:$82 - EVAP Monitor (cap off) Test incomplete or dependant test failed -- MID:$3b TID:$80 - EVAP Monitor (0.090") Max: 779.75Pa Min: -8,192Pa Test result value: 102.75Pa PASS ---- MID:$50 TID:$0e - O2 Heater Monitor Bank 4 - Sensor 4 Max: 0 Min: 0 Test result value: 48,000 FAIL ---- MID:$90 TID:$0e - Max: 0 Min: 0 Test result value: 48,000 FAIL ---- MID:$a1 TID:$80 - Misfire Monitor General Data Max: 24.49993% Min: 0% Test result value: 0% PASS ---- MID:$a1 TID:$81 - Misfire Monitor General Data Max: 0.99953% Min: 0% Test result value: 0% PASS ---- MID:$a1 TID:$82 - Misfire Monitor General Data Max: 24.49993% Min: 0% Test result value: 0.74927% PASS ---- MID:$a1 TID:$83 - Misfire Monitor General Data Max: 0.99953% Min: 0% Test result value: 0% PASS ---- MID:$a1 TID:$84 - Misfire Monitor General Data Max: 966.60004°C Min: 0°C Test result value: 597.29999°C PASS ---- MID:$a2 TID:$0b EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 1 Data Max: 65,535 Min: 0 Test result value: 0 PASS ---- MID:$a2 TID:$0c Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 1 Data Max: 65,535 Min: 0 Test result value: 0 PASS ---- MID:$a2 TID:$80 - Misfire Cylinder 1 Data Max: 24.49993% Min: 0% Test result value: 0% PASS ---- MID:$a2 TID:$81 - Misfire Cylinder 1 Data Max: 0.99953% Min: 0% Test result value: 0% PASS ---- MID:$a3 TID:$0b EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 2 Data Max: 65,535 Min: 0 Test result value: 0 PASS ---- MID:$a3 TID:$0c Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 2 Data Max: 65,535 Min: 0 Test result value: 0 PASS ---- MID:$a3 TID:$80 - Misfire Cylinder 2 Data Max: 24.49993% Min: 0% Test result value: 0% PASS ---- MID:$a3 TID:$81 - Misfire Cylinder 2 Data Max: 0.99953% Min: 0% Test result value: 0% PASS ---- MID:$a4 TID:$0b EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 3 Data Max: 65,535 Min: 0 Test result value: 0 PASS ---- MID:$a4 TID:$0c Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 3 Data Max: 65,535 Min: 0 Test result value: 0 PASS ---- MID:$a4 TID:$80 - Misfire Cylinder 3 Data Max: 24.49993% Min: 0% Test result value: 0% PASS ---- MID:$a4 TID:$81 - Misfire Cylinder 3 Data Max: 0.99953% Min: 0% Test result value: 0% PASS ---- MID:$a5 TID:$0b EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 4 Data Max: 65,535 Min: 0 Test result value: 0 PASS ---- MID:$a5 TID:$0c Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 4 Data Max: 65,535 Min: 0 Test result value: 2 PASS ---- MID:$a5 TID:$80 - Misfire Cylinder 4 Data Max: 24.49993% Min: 0% Test result value: 0% PASS ---- MID:$a5 TID:$81 - Misfire Cylinder 4 Data Max: 0.99953% Min: 0% Test result value: 0% PASS ---- MID:$a6 TID:$0b EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 5 Data Max: 65,535 Min: 0 Test result value: 0 PASS ---- MID:$a6 TID:$0c Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 5 Data Max: 65,535 Min: 0 Test result value: 2 PASS ---- MID:$a6 TID:$80 - Misfire Cylinder 5 Data Max: 24.49993% Min: 0% Test result value: 0% PASS ---- MID:$a6 TID:$81 - Misfire Cylinder 5 Data Max: 0.99953% Min: 0% Test result value: 0% PASS ---- MID:$a7 TID:$0b EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 6 Data Max: 65,535 Min: 0 Test result value: 0 PASS ---- MID:$a7 TID:$0c Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 6 Data Max: 65,535 Min: 0 Test result value: 0 PASS ---- MID:$a7 TID:$80 - Misfire Cylinder 6 Data Max: 24.49993% Min: 0% Test result value: 0% PASS ---- MID:$a7 TID:$81 - Misfire Cylinder 6 Data Max: 0.99953% Min: 0% Test result value: 0% PASS ---- MID:$a8 TID:$0b EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 7 Data Max: 65,535 Min: 0 Test result value: 0 PASS ---- MID:$a8 TID:$0c Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 7 Data Max: 65,535 Min: 0 Test result value: 2 PASS ---- MID:$a8 TID:$80 - Misfire Cylinder 7 Data Max: 24.49993% Min: 0% Test result value: 0% PASS ---- MID:$a8 TID:$81 - Misfire Cylinder 7 Data Max: 0.99953% Min: 0% Test result value: 0% PASS ---- MID:$a9 TID:$0b EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 8 Data Max: 65,535 Min: 0 Test result value: 0 PASS ---- MID:$a9 TID:$0c Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 8 Data Max: 65,535 Min: 0 Test result value: 1 PASS ---- MID:$a9 TID:$80 - Misfire Cylinder 8 Data Max: 24.49993% Min: 0% Test result value: 0% PASS ---- MID:$a9 TID:$81 - Misfire Cylinder 8 Data Max: 0.99953% Min: 0% Test result value: 0% PASS ---- End of report. |
Anyone know how to read these tests?
I have the same "error" showing on my 05 5.4 when I scan with Torque Pro......"O2 Heater Monitor Bank 4 Sensor 4 Current 48,000. Not OK"
Does anyone know what this means? |
