so i ahve a 97 f 350 2 wheel. wondering if there is anything you can do to get better mileage , i have the kn air system. is all the aftermarkets parts. let me know
Get rid or the K&N and get this from Riffraff....Riffraff Diesel
The K&N filters let too much fine dust through and will dust the cylinder walls of your engine. The 6637 filters a lot better and flows more air. Pull your intake tube off the turbo and see if the compressor wheel looks like it's been sand blasted on the edges.
I know the WMI is good for EGT's but because it creates a steam engine effect, you engine will be a lot cleaner as well, combustion would be more efficient. As well as it slightly raising the BTU's of your fuel, allowing for better combustion as well. I guess that is why some will say they notice a small gain in fuel economy(using electronic gauges, odometer vs distance calculations, etc).
What about Bio-diesel, if you can run a vegetable oil based fuel, you could technically consider that as gaining fuel economy, because you aren't burning as much diesel to cause combustion, just during start up, and shutdown. I've noticed a few of these trucks on youtube that utilize the rear tank as bio, and add a separate fuel pump/filter for it.
paying less for diesel, and practically nothing for a larger quantity of bio would be a win in my book.
The setup would be a determining factor naturally, but would pay itself off relatively quickly, depending on how many times you would fill up.
Let me know if my reasoning is off on this, because I plan to do this at some point down the road.
Me personally, If I was going to do biodiesel, I think I would do it with an IDI engine. I think it can cause too many problems with our injectors, that's just me though.
Because of the Direct injection, or incompatible injectors? I guess it would depend on viscosity, otherwise, you can always get bigger injectors. Most of them I've seen were IDI, hard to find powerstroke videos on youtube. But they all used electric fuel pumps.. Would electronic fuel injection be possible with these trucks? That might mitigate problems of too much/little bio getting to the fuel intake. I've been looking, but haven't found my ECU anywhere, or a place to plug in a diagnostic scanner.. If you could hook one up, you could monitor it to find out.
Guys do run bio and filtered WMO in these from time to time. I personally would never run bio, for one, because of all the work needed to convert the fuel system to handle it. I have thought about running WMO filtered down to 1/2 micron, and cutting it with regular #2 pretty heavily.
You can do e-fuel on these trucks, but I talked to Jim Rose and he said it was something to do with the chemicals used to wash the bio if I remember correctly. Don't quote me or Jim on that cause I'm not 100% sure, I can't recall the details of the conversation.
Your OBD port is under the dash over by the glove box, but there are only a few scan tools capable of scanning our trucks.
