tail light housing
Old Dec 15, 2012 | 04:16 PM
Flyn66dtmn's Avatar
Flyn66dtmn
tail light housing
It's been awhile since i have been on the this site, life got in the way. LOL I paged through all the books that i have looking for tail light housings, LMC, Dennis carpenter, NPD. they all have the lenses and trim but no housings, anyone happen to know where i can find some. 66 F-250. thanks in advance.dutch
Old Dec 15, 2012 | 06:15 PM
BurlyCrew's Avatar
BurlyCrew
You looking for the Corner Posts of the bed?
Old Dec 15, 2012 | 09:56 PM
TA455HO's Avatar
TA455HO
Lead Gopher
Assuming 2WD the housings should be part numbers
C4TZ-13434-B - RH
C4TZ-13435-B - LH
JST Automotive in Lebanon, TN has one of each. Give them a call at
615-443-3086 on Monday.
Old Dec 15, 2012 | 10:10 PM
Boss9F100's Avatar
Boss9F100
C4TZ-13434-B - RH
C4TZ-13435-B - LH
TA HO did you see the NOS 4x4 Battery Box on epay?
Old Dec 16, 2012 | 10:43 AM
TA455HO's Avatar
TA455HO
Lead Gopher
Thanks. Got it. That's two spares on the shelf so hopefully that'll do since both trucks have decent trays, too.
Old Dec 16, 2012 | 12:47 PM
37 Ford guy's Avatar
37 Ford guy
Hey TA455HO, here's a listing of all the housings that will fit your truck according to Number Dummy, assuming that it's a styleside bed.
"1964/66 F100/250 2WD & 1966 F100 4WD Stylesides, 1966 Bronco use the same tail lamps assy's.
1967: Ford introduced backup lamps. 1967/72 F100/350 Stylesides, 1967/77 Bronco's and 1969/74 Econolines use the same tail lamp assy's, have the backup lenses incorporated within the lens.
These lamps will fit the above 1964/66 trucks like they were made for them. Bolt right on...but...you'll have to figure out the wiring and where to mount a backup light switch."
Old Dec 17, 2012 | 06:45 AM
Flyn66dtmn's Avatar
Flyn66dtmn
thanks guys, will call them today, may put the backup lights on it as the truck has so many mods on it that one more isnt gona make any difference. i didn't realize that the ones with the back up lights went to 1977, may even get them here.
cander06
Nov 3, 2018 11:06 PM
alchemist1
Jan 17, 2013 04:26 PM
ChristopherN
Oct 22, 2012 03:44 PM
retroluxe
Dec 30, 2006 06:50 PM
