Trying no sways
Old Dec 15, 2012 | 12:14 AM
bakos's Avatar
bakos
Trying no sways
97 f250 460 4" lift twin beam. Took both sways off, so far only tested it around the hood but towing through the hills tomorrow. Just the short spin I've done so far seems pretty firm. I'm working on TWO things. Trying to smooth out the ride and getting the sways installed proper. I just put the skyjacker lift on and my front sway bar just isn't rite, as it goes under the spring it only clears it by 1/4" or less - the links for the kit are waaay longer so that ain't rite. The only thing I could see would be to drop the sway where it mounts in the front center. If anyone could shed lite on how to install or imput on just not running them - that would be great. NOTE: I do have bags in the rear I use only for heavy loads
Old Dec 15, 2012 | 10:37 AM
rla2005's Avatar
rla2005
Sway bars are there for a reason. Hard core off-roaders disconnect or completely remove them so they do not restrict suspension travel. On a street driven vehicle the sway bars are just that....they keep the vehicle from leaning too far when cornering. If the link bars in the kit are too long then I suspect they sent you the wrong ones.
I would not want to be in your vehicle when you are towing through the hills with a lifted suspension and no sway bars.
Old Dec 15, 2012 | 06:25 PM
bakos's Avatar
bakos
Just got back. Towing 18' river jet with 393 in it. 70 on the freeway 50ish thru hills. Ride is much nicer. Truck always drove really straight I think the new springs are way stiffer the stock ones and that combined with improperly setup sways, just made it way to stiff. I'll keep working on getting my sways set up proper. But for now its way better with out. I don't see any safty issues, drove all roads at posted speeds (40 corners at 50) with some ruts, bumps standing water and I couldn't notice ANY body roll or looseness. Unless I'm missing something? It seems way safe. If you think I'm overlooking something please let me know. Like I said I'll keep working on the sways but for now I sure like it better without
Old Dec 15, 2012 | 06:50 PM
Bansheesandrider's Avatar
Bansheesandrider
Ford included swaybars with their towing and camper packages for a reason- the heaveir weights need more help keeping it under control. Swaybars should not cause a stiff ride cruising down the road where both wheels are going through the same oscillations, they are there to transfer the up travel of the outside wheel/tire to the inside wheel/tire when going around a corner resulting in less boddy lean.
One thing to keep in mind- if you are involved in an accident with your swaybars unhooked you could be at fault because you have disabled some of the factory equipped safety equipment.
Old Dec 15, 2012 | 07:20 PM
bakos's Avatar
bakos
Ok thank you. I'll get them figured out. I think the front sway needs mount drops not different end links like skyjacker sold me. The way I've been running them (installed the same as before the 4" lift) if definitely effects the ride. You could see, it's like leavening the sway connected and putting a 4" lift just isn't rite, stretching the system so the bar comes off the end link at a 45 instead of a 90 deg angle.
Also was told and are you saying some trucks just like mine did not come with sways
Old Dec 15, 2012 | 09:01 PM
firerescue9's Avatar
firerescue9
i actually disconnected mine yesterday too. sofar its alotttttt better. the ride is much smoother, and ive seen no issues with body roll or anything
Old Dec 16, 2012 | 02:43 AM
Andrew James's Avatar
Andrew James
The Bronco forum is full of well respected individuals in our online community that say ditch them. I took them off my 1991 Bronco and noticed no difference. My lifted 89 Bronco has them but IDK, too lazy to take em off or care.
Old Dec 16, 2012 | 10:26 AM
Bansheesandrider
Ditching them is great on a vehicle that is used OFF ROAD- the Wrangler Rubicon and Dodge Power Wagons even come with electric disconnects from the factory. BUT on the road towing or carrying a heavy load they should be functional- the ones on the Wranglers even reconnect automatically when you get above 18 MPH.
Old Dec 16, 2012 | 10:34 AM
444dieselrod's Avatar
444dieselrod
Apparently none of you have looked under a diesel ford truck.....no sway bars to been see. In fact i will bet that 75% of these trucks DON'T have sway bars and so far i dont think anyone has gotten sued because they didnt have them.
If you like the truck without them leave them off and go on with your life.
Diesel Rod
Old Dec 16, 2012 | 07:55 PM
Bansheesandrider
Diesel Rod
EVERY Ford pickup that was camper certified by Ford at the factory came with swaybars.Swaybars and overload springs, and maybe Super Cooling, is what made up the camper package. Most of the diesel trucks I have looked at around here have the swaybars. I have driven a F250 without swaybars hauling a 9.5 foot camper and it was scary when you encountered a semi truck. My current F250 is camper certified and when I meet a semi it barely rocks.
Old Dec 16, 2012 | 07:57 PM
Andrew James
What is this "off-road" you speak of?
Old Dec 16, 2012 | 08:01 PM
Bansheesandrider
Off the paved roads, on the trail, cross country travel, in the boonies, travelling in the sand dunes, etc.
Old Dec 16, 2012 | 08:03 PM
Andrew James
Old Dec 17, 2012 | 03:09 PM
444dieselrod
All 3 of my trucks are diesels, 2 have factory overload springs and 0 have swaybars. I have seen ALOT of OBS Ford diesels and i dont think i have seen a single 3/4 ton with a sway bar, i have seen 1ton diesels with the rear sway but never a front sway, the radiator is in the way.
My point is ALOT of trucks are running around without swaybars from the factory and they handle just fine.
Diesel Rod
Old Dec 17, 2012 | 04:30 PM
GNR22's Avatar
GNR22
My F250 had front and rear sway bars when I bought it. I removed the front sway bar when I did the SAS. I removed the rear sway bar shortly after because the bushings were going out of it.
