How hard should it be
Old May 24, 2003 | 09:23 PM
EricB's Avatar
EricB
I just did a teardown on a 79 302,installed new rings and did a valve job,Now the engine is hard cranking,how hard should it be to start?
Old May 25, 2003 | 03:05 AM
macguyver's Avatar
macguyver
It'll be a little stiffer than a worn engine but shouldn't be too hard to turn over. Did you check the gap on the rings? Did you clean off the new paint on the ground cable connection at the block?
Old May 25, 2003 | 11:56 AM
EricB's Avatar
EricB
yes the specs on the gap came out good,I will check the ground again.Thanx
Megadiesel08
Dec 22, 2012 09:01 PM
2005f-150
Jan 30, 2012 07:30 PM
sparkkky
Nov 1, 2011 12:36 PM
onetuff350
Mar 21, 2005 07:02 AM
79FordF100
13
Aug 18, 2002 03:04 AM
