460 distributor?
Old 12-10-2012, 01:26 PM
glw165's Avatar
glw165
glw165 is offline
460 distributor?
initial time is @ 14*, and when reving it stops @ 30, however i noticed at idle that with vacum hooked or unhooked it doesnt move with the light, so i assume a bad diaphram?, also will a 351m dist work?
Old 12-10-2012, 04:43 PM
pacific350's Avatar
pacific350
pacific350 is offline
If you are runing a high lift cam the vacume is going to be weak (10-11 peaks) to begin with, that could possibly explain not having a change.
Old 12-10-2012, 05:09 PM
glw165's Avatar
glw165
glw165 is offline
bought motor as is i really dunno what cam is in it, but they told me mild, anyways i bought new distributor, def helped vacuum now moves on the light, better response off bottom as well, has a new 1411 eddy carb, truck has 3.50 gears, not much off idle but mid raNGE it comes on hard, so hard in fact if roads lil dirty it breaks loose, but dog on bottom, kinda wierd, has dove-c heads its a 71 model block, runs ok but looking for more off idle
Old 12-10-2012, 05:55 PM
beetle's Avatar
beetle
beetle is offline
Your vacuum source is probably using the "timed" source as opposed to the manifold vacuum source, which only applies vacuum when reving, look to see where it is hooked up. Hook it to a manifold port and the timing should increase quite a bit, if not the diaphram could be bad.
Old 12-10-2012, 06:38 PM
glw165's Avatar
glw165
glw165 is offline
Its on full manifold vacum, it was the diaphram, i replaced whole distributor, which im glad i did causevafter old dist out, seen it had wobble in shaft, bad bearing, so now i have vac advance combinef with mech advance, runs better but not as crisp on bottom as id like
Tkc432
22
07-06-2015 06:14 PM
JFlom77
11-12-2014 04:08 AM
longhorns13
04-18-2008 03:18 PM
orange784x
11-07-2007 07:58 PM
ErrorS
10-17-2007 09:21 PM
Quick Reply: 460 distributor?
