Sputters When Put Into Park
Old Dec 13, 2012 | 12:40 PM
Rynil2000's Avatar
Rynil2000
Unhappy Sputters When Put Into Park
Hey guys, I've been to the site a few times before, but this is my first time posting.
I'm driving a 2001 Explorer Sport Trac 4.0 V6, and it has been acting strange lately. When ever you shift into park the truck sputters 3-5 times and sounds like it's going to shut off, but then returns to a steady idle. So far it hasn't cut off, but it sounds really rough.
This only happens when you shift from drive to park. I can do it multiple times while sitting still and it will sputter every time, but recover as before. I tried going from neutral to park and the sputter didn't happen.
Otherwise, the truck runs fine; starts and drives well. I recently replaced the DPFE sensor to clear a "check engine" code. I'm not sure if that would have something to do with this problem. The check engine light is off.
I have no idea what could cause this issue. Any help is appreciated.
Old Dec 13, 2012 | 01:20 PM
aquanaut20's Avatar
aquanaut20
Your Idle Air Control Valve (IAC) is acting up, try cleaning with CRC Intake solvent... Philip
Old Dec 14, 2012 | 03:11 PM
Rynil2000's Avatar
Rynil2000
Thanks for the info. I took a look at the engine, the oil filler is on the passenger side, plus the build date on the door sticker is 08/01; so now I know it's a job 2.
Since the truck has 220K+ miles on it, I'm just going to go ahead and replace the IAC valve. I'll take a look at those rubber elbows while I'm in there.
On another note: This used to be my dad's truck. It had been running the "bad DPFE sensor" code for at least 4 years before I replaced it. I asked him about a burning oil smell coming from under the hood. He said that he thought there was a leaking gasket around a valve cover. Could this be the source of the issue? I'm sure this isn't something to brush off lightly. Any idea how much a mechanic would charge for this repair? I don't have the tools or the time.
Old Dec 14, 2012 | 04:43 PM
aquanaut20's Avatar
aquanaut20
Common for valve cover to leak, check driver side rear. A 1/4 flex drive and socket will fix....,$5.00 to buy set, $100+ for mechanic.... Philip
Old Dec 19, 2012 | 09:01 AM
Rynil2000's Avatar
Rynil2000
Well, you guys are good. I replaced the IAC valve this past weekend and the sputtering problems seemed to be solved. It was a really easy replacement. A few times it's dropped the RPMs kinda low when putting it in park, but no where near like it was doing. I'm going to try replacing the PCV valve and that pesky vacuum hose elbow that everyone keeps mentioning, just for good measure.
jerrymcox
Mar 14, 2018 08:44 AM
old-dad
1997 - 2003 F150
Jul 8, 2017 11:48 AM
hillbillyford
1983 - 2012 Ranger & B-Series
16
Sep 2, 2010 08:24 AM
bjis
Sep 6, 2007 10:24 PM
TennesseeGuy
1997 - 2003 F150
Jun 8, 2006 03:31 PM
