6.9 not running right help please
Old Dec 13, 2012 | 11:06 AM
79sparky's Avatar
79sparky
When driving my 85 f250 6.9 idi it keeps loosing and gaining power. Ill have the throttle held in to the floor and it will act like I keep pressing depressind the gas peddle. And ideas on what might cause this
Old Dec 13, 2012 | 12:01 PM
monte97z's Avatar
monte97z
Plugged fuel filter could do it. Any other symptoms like smoking, overheating, hard stars after its been sitting?
Old Dec 13, 2012 | 12:20 PM
79sparky's Avatar
79sparky
It doesnt start hard when its plugged in sometimes you start it up after youvdhad it running it'll stall then it starts hard, and yesterday it stalled when I was sliwing down to turn into a road
Old Dec 13, 2012 | 12:44 PM
monte97z's Avatar
monte97z
Could have an air intrusion problem. How many miles are on the IP and injectors? Any of the return lines look wet and do u still have the stock water seperator hooked up?
Old Dec 13, 2012 | 12:52 PM
79sparky's Avatar
79sparky
141k miles on everything none if the return lined appear wet I do smell some diesel under the hood though, and no the stock water separator is not hooked up.
Old Dec 13, 2012 | 02:55 PM
monte97z's Avatar
monte97z
You r due for an IP and injectors most hrere will recemond them every 100k as they r both wear items. I do not think that is your current problem tho. Simple test for air intrusion is after she sits overnight take off the fuel filter. If it is full to the top you are good if not then you have air intrusion. But I would first swap the fuel filter and go from there that may clear it up.
Old Dec 13, 2012 | 03:15 PM
79sparky's Avatar
79sparky
Alright ill put a new filter on tomorrow and see were the fuel level is in the filter when I take it off, should it be like almost over flowing full?
Old Dec 13, 2012 | 04:07 PM
monte97z's Avatar
monte97z
Yes should be right up to the top basically spilling out
Old Dec 13, 2012 | 04:12 PM
79sparky's Avatar
79sparky
Alright thank you ill keep ya posted then
Old Dec 13, 2012 | 04:14 PM
gingrass179's Avatar
gingrass179
i had this same problem when i first got my truck it started off as a quarter tank problem how it would run out of fuel than it turned it alternating power levels than it died a couple times and fuel filter light would come on anything after 55 or hard acceleration i had bought a new filter nothing changed disconnected lines from tank and from tank selector and blew them out and tons of plastic came out????????my thought it was parts of the old pickups but i had to buy a new selector clear lines in tanks drop both tanks etc never had a problem since
Old Dec 13, 2012 | 04:22 PM
bashby's Avatar
bashby
Yeah, it sounds like you may have a leak on the suction side of the lift pump. Inspect the line along the frame and check your fuel level... above half should be plenty even if the shower head is broken off in the tank.
Old Dec 13, 2012 | 04:35 PM
79sparky's Avatar
79sparky
Yeah the shower heads already busted off and the po just put a piece of rubber line on in place lol. And I dropped the tank not to long ago to do some modifications go the filler neck and there was a piece of plastic in the line ill have to check that aswell, suppose I could see if it does it with the rear tank just so happenes I haven't used that tank since this happened, ill also chech the lines I smell some diesel under the hood so ill check the lines to ghe fuel pump
Old Dec 13, 2012 | 04:38 PM
gingrass179
if you saw one piece of there plastic there will be a ton more i just drained both tanks and reached in and cleaned everything out and blew all my lines out...you should be good after that
Old Dec 13, 2012 | 04:40 PM
79sparky's Avatar
79sparky
Yeah ill chech em out this weekend its a shame the front tank is full
Old Mar 5, 2013 | 11:01 AM
barely alive's Avatar
barely alive
Tank/Fuel pick up. Where to start?
I wonder where to start? I guess it would be good to look at lines and tanks. I know both tanks were completely full. Mine has a skid plate below tanks to protect them. I guess it is best to drain fuel otherwise it is like wrestling an 80 pound jug of unstable liquid over your head. Can line be cracked open somewhere and a drain line be routed to a container or do you just prepare to try dropping it full? I wonder about working just past the selector. If unhooked there can you switch front to rear to start and stop flow? Maybe this would be a good way to check flow from tanks before guessing about the need to drop them.
