Charging or drain issue
Old Dec 13, 2012 | 12:10 AM
91dirtydiesel's Avatar
91dirtydiesel
So a while back I did the 87-91 headlight harness upgrade. Just recently my brights must have either burned out, or are shorting somewhere? When I click the brights my headlights go out completely, And the strange thing is that it creates a load on my charging system.
At idle with no accessories my batteries read 14.2v. When everything is on (lights, heater, electric fuel pump, wipers) it drops to 13.0v. Ok, I understand it creates quite the load...but is causes my cold starts (after sitting 12 or so) to be rather difficult. When I first turn the key my e pump turns on, then when I hit my glowplug switch the volts drop like crazy. Barely turning over fast enough to make her start.
I got a good deal on some optima red tops so I switch my old sears batteries out, this did help but something is still not right.
So I'm wondering if something might be causing it to drain (high beams ? ) or if my alternator is struggling (-7 years old)
Any thoughts/suggestions/comments would be great!
Old Dec 13, 2012 | 01:07 AM
kc0stp's Avatar
kc0stp
So with truck running and high beams turned on the volt gauge drops big time? If so first thing I would do is fix the brights after that measure how much amperage the alternator is putting out under full load (if its dropping a full volt Im guessing your maxing it out but measure to see) might also see if any parts store has a on vehicle tester for alternators. Not as accurate as taking it off and testing but can give you some good info all the same.
Other thing you want to test is with truck and everything turned off measure how many amps are being pulled on the batteries (amp clamp around the positive cable after right side battery if you have one)
Old Dec 13, 2012 | 01:18 AM
91dirtydiesel
Whenever I change any accessory setting from high-low, even my electric windows makes that battery guage jump around alot. I'll take a video tomorrow of that.
Not sure what you mean with your second paragraph, "after right side of battery" both my batteries are on the right side lol ? ...and no I don't have an amp clamp, I'll look into that tho
Old Dec 13, 2012 | 02:14 AM
gingrass179's Avatar
gingrass179
are you mainly noticing the problem the most at startup? as in you let it sit overnight and wake up and you can only crank over once before it starts slowing down?
Old Dec 13, 2012 | 07:25 AM
tjc transport's Avatar
tjc transport
i ain't rite
13 volts with everything on is fine. it sounds like you have a tired starter.
here is a bad starter at 70 degrees:
and here is a new starter at 40 degrees:
Old Dec 13, 2012 | 07:48 AM
bashby's Avatar
bashby
That's a great set of video's you made there, Tom. Thanks for posting them again.
A bad connection or battery cable can also cause slow cranking like video #1 also. Mine was cranking a little slow and I could see the connection at the starter glowing hot. I ended up having to replace the starter anyway, the lug broke out when trying to remove it.
Old Dec 13, 2012 | 01:32 PM
91dirtydiesel
YES this is it! compare the sound from your first video to my video
struggling to say the least....
Old Dec 13, 2012 | 02:16 PM
tjc transport
i ain't rite
definitely either a bad starter, bad positive cable, or both.
also with the glow plug controller bypassed with the manual toggle switch, you have no after glow. that is why it keeps dying after starting
Old Dec 13, 2012 | 02:17 PM
Opossum's Avatar
Opossum
Wow I wouldn't want to rely on that starting on a snowy morning. As you know I'm new to these but I think you have a few issues there, each making the other worse. Seams to me Tom has a point about your starter and the slow cranking is your biggest issue. Of course check cables and connections. On a cold morning after a bit of cranking without starting I'd go around and feel the cables, connections, starter etc for heat. Anything hot is bad. I actually melted a bad lead cable clamp a while back.
Also to toss in, seams you have an issue with it staying running, that should be worth dealing with. Even my junk stays running once it fires. Also I don't know if you start it every day but I and a few others have had issues of optimas connected in parrallel draining each other over time. I installed a pac-500 continious duty 500 amp solenoid as a battery isolator for good measure.
Old Dec 13, 2012 | 02:22 PM
tjc transport
i ain't rite
sitting should not make any difference. my 88 will sit for weeks without firing. i will go out in a few and fire it up. the last time i started was back in the end of september when i parked it after putting the rear springs in it.
here ya go. it is around 43 degrees outside.
Old Dec 13, 2012 | 03:05 PM
91dirtydiesel
Opossum, the not staying running was a combination of slow cranking and like Tom said, no after glow. Usually one it fires I flip the plugs on for a couple seconds and it keeps running...but I didn't for videos sake lol
In process of changing starters, top bolt is major PITA.
Old Dec 13, 2012 | 03:16 PM
tjc transport
i ain't rite
yes it is. the funny thing is, no matter how many starters you change, you still forget how to take it out and have a hard time. but it goes back in super easy.
make sure you disconnect both batteries before you start taking the starter out.
Old Dec 13, 2012 | 03:40 PM
91dirtydiesel
here is a quick video comparison....i found a starter laying around in my IDI parts pile so its used with unknown miles...but seems to spin better
i dont have ignition on so it will not start, just showing spin speed
old starter
new (used) starter
Old Dec 13, 2012 | 03:46 PM
tjc transport
i ain't rite
the starter you put is definitely in better shape, but it is still a bit tired.
i would get the one you pulled out rebuilt if you have a good rebuilder in your area.
Old Dec 13, 2012 | 03:54 PM
91dirtydiesel
ok great, ill search for one. now i need to figure out my brights LOL, ill go into my old thread and post up. thanks for the help
