Any experience with these?
Old Dec 12, 2012 | 07:57 AM
GOTUBCH's Avatar
GOTUBCH
So I just installed some new tires on my truck and they are rubbing some so I was looking at doing a leveling kit on it. Anybody have experience with these?
Thanks,
99 04 Ford Superduty 2" Front Leveling Lift 4x4 F350 | eBay
Old Dec 12, 2012 | 08:16 AM
Jmatthews's Avatar
Jmatthews
is a BAAAD MAN
I put them on my Excursion 3 years ago and have been happy with them. I didn't add all the leaves as I only needed 1 1/2" of height.
Old Dec 12, 2012 | 04:08 PM
XbigXredX's Avatar
XbigXredX
How does that work with the rear? Do you get a 2" lift in front and nothing in the rear?
Old Dec 12, 2012 | 04:38 PM
Jason 05 EB's Avatar
Jason 05 EB
Plenty of people say you should swap out the stock front springs to V code springs. I purchased a set new for $350, but found a used set in the junk yard for $180. Not only does this raise the front, it gives you more stability (less rocking side to side). I'm waiting for my Y Pipe to come in and do it all at once so I have no pictures to share. I'm also adding a RAS to the rear.
Old Dec 12, 2012 | 06:13 PM
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
i went with front lift shackles two years ago on my '02 have been very happy with them so far.
Old Dec 12, 2012 | 08:21 PM
GOTUBCH's Avatar
GOTUBCH
I already have a 8 inch lift needing a little more to clear my 42s an OEM spring swap is not an option
hasteranger
Aug 30, 2013 09:41 PM
The_Punisher
Apr 30, 2012 04:35 PM
yield2s
Apr 3, 2008 09:45 AM
jamesbfishin
Mar 10, 2004 09:35 AM
2BIGFORDSUVS
Aug 9, 2003 09:13 AM
