But the body lines on the wheel well arcs are different from 11-up. It will bolt up you may or may not have to fiddle with the wiring to the tail lamps to get everything where it needs to be.
I dont think its too noticebale, a true blue bleeder will notice right away, but most wont. If you try and search there was someone here not too long ago that did it on an 03 and it didnt look all that bad to me.
yes it fits but it looks like CRAP! body lines are completely different, wheel wells are more bubbled and rounded. If you need a bed just keep looking for one or just fix the one you have
I remember seeing that one that was posted. IIRC, the body lines were the same, but the wheel opening was made different than the original. It looked fine and only a "true blue" bleeder would catch it.
I don't think it's so much the wheel well opening, but the flared out portion around it is stamped differently I believe. They are a little rounder, and there is a little round indentation around the wheel well flared portion that isn't there on the older beds.
You probably wouldn't notice it from far away, but up close i'm sure I would notice and it would bug me.
