Window gets stuck when lowering
Old May 24, 2003 | 02:04 PM
biederboat's Avatar
biederboat
I have a drivers window on an Aerostar that gets "stuck" when lowering. The front part drops right away and sticks, you have to put pressure on the rear portion to keep it level. The only thing I can figure out is that the rubber moulding is worn in the front and gotten kind of "grabby" as some of the fuzz is worn off. Does this sound right? If you keep the window level, it goes up and down just fine.
Thanks,
Mark
Old May 24, 2003 | 10:15 PM
cid's Avatar
cid
You need to remove the door panel. Inside you will see how the window operates. By winding the window up and down you will soon see the problem. The operation is very simple. The window runs in two channels. The regulator (hand crank) does the lifting.
Old May 26, 2003 | 10:08 AM
biederboat's Avatar
biederboat
Actually I have been through this many times, having even replaced the crank mechanism to no avail. Can anyone tell me if there is some type of lubricant I can use on the weather stipping (asuming it will help)?
Thanks,
Mark
Old Jun 1, 2003 | 12:59 AM
cid's Avatar
cid
Try some white lithium grease on all the metal friction points inside the door.
Old Jun 1, 2003 | 12:00 PM
biederboat's Avatar
biederboat
Actually, it ended being the rubber moulding that was grabbing the window too much, silicon spray lube did the trick.
Old Jun 3, 2003 | 10:20 PM
Aerodude's Avatar
Aerodude
What seems to really be the problem with Aero windows is the rubber track wears out and the glass shifts a little and that's what binds it. The lube helps the shifted glass move but it only a temp fix.
Korkster
Jul 18, 2015 09:42 AM
teerex
Nov 11, 2013 08:30 PM
rjeremyj
1983 - 2012 Ranger & B-Series
Nov 22, 2010 08:43 AM
Larry85355
Apr 14, 2008 10:49 PM
old red ranger
Jan 25, 2007 07:56 PM
