Not starting
Old Dec 10, 2012 | 11:37 AM
fire19's Avatar
fire19
Not starting
I have a 2000 F-350 Dually witha factory Security system and TS Performance chip It will not start. I tested the voltage from the battery to
solenoid and I got 12.6V but the other side I get .1485V with the Key switch in the starting position I also get .1485V on the smaller post on the
solenoid that I think comes from the key switch, the compressor magnet does makes a click. Has anyone had this issue and what did you find.
Old Dec 10, 2012 | 12:22 PM
SkySkiJason's Avatar
SkySkiJason
No power to the starter?
I'm not sure what could cause this... But, I'd suspect neutral/park safety switch. Will it start with shifter in neutral?
Old Dec 10, 2012 | 01:29 PM
fire19's Avatar
fire19
This is a automatic I thought you could only start it in park but I will try when I get home.
markeyd
Feb 21, 2016 07:32 PM
Maine_Lobsterman
Mar 3, 2015 09:38 AM
Hondo427
Dec 4, 2013 01:19 PM
chrisginco
22
May 14, 2013 12:17 AM
hollywoodswole
May 24, 2011 09:03 PM
