Tuff Country Kit
Old Dec 9, 2012 | 09:19 PM
BattChief's Avatar
BattChief
Tuff Country Kit
Has anyone installed the 3 inch Lift Kit offered by Tuff Country for the 2012 F150 yet? A few parts houses are selling it but there is no info about this new kit on the Tuff Country website.
Old Dec 9, 2012 | 09:21 PM
Jake85388's Avatar
Jake85388
Originally Posted by BattChief
Has anyone installed the 3 inch Lift Kit offered by Tuff Country yet? A few parts houses are selling it but there is no info about this new kit on their website.
My close friend brags about tough country all the time and he is a full time mechanic, I trust his word. Just remember to get an alignment
Old Dec 10, 2012 | 06:30 AM
D8chumley's Avatar
D8chumley
Resident smarta$$
I found this
Ford 3" Suspension Lift Kit F150 4wd 2009-2012 - Tuff Country 23000 - 2010 2011
I think I like that it comes with new UCA's so I assume it helps with the angles a LK puts the stock control arms at, and I think I see grease zerks also If you go with this kit make sure to come back and post your comments
Old Dec 10, 2012 | 09:26 AM
Jake85388's Avatar
Jake85388
Originally Posted by D8chumley
I found this
Thats a decent kit, looks pretty simple too. Hope you get it so we can see it installed
Old Dec 11, 2012 | 11:27 PM
BattChief's Avatar
BattChief
Ok so ... I guess I may be the guinea pig then. Well here is my dilemma. I have a 2012 XLT Screw 4x4 w/ the 6.5 bed (Black, of course ).
I have installed the Autospring 2.5 Leveling kit in the front ( didn't put the blocks in the back because I like the way the truck sits now ) and put 295/70-18 Nitto Trail Grapplers on 18x8.5 XDseries Spy's on it. My truck looks good ! But....I am getting a small amount of rub in the front when I back up and cut the wheels, like backing out of the driveway too sharp.
I am wondering if this kit would get me the lift I need to stop the rub. The price difference in this kit and a 4 inch kit is nearly.....$1000 bucks ( without install ).
What do yall think?
Old Dec 12, 2012 | 05:36 AM
D8chumley's Avatar
D8chumley
Resident smarta$$
Is it actually rubbing or is it the TC kicking in? I have almost the same as you and I get that scraping noise also, when I am turning and the truck encounters any slight off camber situation
Old Dec 12, 2012 | 08:28 PM
BattChief's Avatar
BattChief
Yea, it's rubbing. It is catching the lower valence on the bumper. I'm trying to get some more pics of the Tuff Country 3-inch kit but havent had any luck. Even called Tuff Country.
I really like the Rancho 4-inch kit but I would be looking at about $2500 or more to have it installed. I would do it myself but there is something about putting a cut-off wheel to my new truck that I just can't get past. I think I will leave that up to "the pro's"!
Old Dec 14, 2012 | 06:26 PM
mrbags's Avatar
mrbags
hey guys i work for tuff country. i saw this so i thought id sign up and answer any questions you had on this kit. so feel free to ask.
Zach
Old Dec 14, 2012 | 10:26 PM
BattChief's Avatar
BattChief
Awesome Zach, just the man we needed to chat to.
As stated earlier, I have the Autospring 2.5 leveling spacers in the front now and was wondering if the 3 inch Tuff Country kit would give me the extra clearance I need to do away with the slight rub.
After reading more on your kit I see that the specs say you can run a 33 inch tire with no mods and a 35 inch tire with minor trimming. Nitto says my tires measure out to like 34.57. I dont know.
I mentioned the Rancho kit in an earlier post but I have used Tuff Country product on an F-250 I had before this truck. It was good stuff. Can you give us the run down on this new kit?
Old Dec 15, 2012 | 12:27 AM
mrbags's Avatar
mrbags
we are running the same tire you have on yours. the only place we had to trim is the front owed plastic on the bumper. far as the back side of the wheel well we did not trim.
when you install leveling kits on these f150s im sure you've seen that the control arm hits the the strut at full droop. we have made the new strut spacers for the 3 inch lift move the top of the strut in so you dont have the strut contacting the control arm. its a very simple clean install. you'll get 3 inches up front and 2 inches in the back. you can find pictures and the instructions here at this link. Ford 3" Suspension Lift Kit F150 4wd 2009-2013 - Tuff Country 23000 - 2010 2011 2012
jwc410
Jan 31, 2017 02:07 PM
riored4v
2004 - 2008 F150
Nov 5, 2007 03:33 PM
WalterP
2004 - 2008 F150
Oct 20, 2007 12:20 PM
FN74
Jun 5, 2007 12:04 AM
