leaf spring shackle bolts
Dec 9, 2012 | 02:38 PM
I'm changing the rear leaf spring on my truck, (it's cracked) and I can't get the bolts out of the shackles. They are seized in the bushings. I took the leaf spring assy off the donor truck without a hitch but ,mine won't budge. I got the nuts broke free. Any ideas/tricks of the trade? I'm committed to taking at least the rear bolt out for I have been using the beating on the nut and it is mushroomed out. Can't get the nut off to replace it until I can get this bolt free.
Dec 9, 2012 | 02:59 PM
penetrating fluid or heat and a really big hammer.
matt
Dec 9, 2012 | 03:07 PM
Ball joint press with a socket
Dec 9, 2012 | 05:03 PM
No dice on either of those suggestions. My ball joint press isn't big enough to put any kind of adapter on it and get it to fit. (press is too short)
Dec 9, 2012 | 05:18 PM
How do you have the truck jacked up?
Jason
Dec 9, 2012 | 06:45 PM
I have the jack+stand under the receiver hitch
Dec 9, 2012 | 06:56 PM
i just swapped out my leafs just the other month and i used a torch and a grinder with a cut off wheel (use atleast a 6" wheel), and a BFH
Dec 9, 2012 | 07:28 PM
That's what I think I'm thinking is gonna have to happen...
Dec 9, 2012 | 07:31 PM
i only had the 4 or 4 1/2" wheel and it wasn't quite enough but the torch finished the job along with the BFH good luck.
Dec 9, 2012 | 07:35 PM
I'd lower the jack some--you may have too much weight hanging from the leaf spring bolt. Let the tires touch the ground a little.
Jason
Dec 9, 2012 | 07:38 PM
Quote:
Originally Posted by
2wheels06
Why at least a 6" wheel?
Dec 9, 2012 | 07:47 PM
because the 4 1/2 just wasn't enough to get all the way through the bolts. atleast that's the problem i had lol
xaviar
Jun 4, 2016 04:18 AM
bigzirb
Jun 16, 2015 08:52 PM
powersmoked
15
Jan 26, 2012 01:17 PM
andyj ford driver
18
Oct 1, 2011 01:03 PM
orangeford
Oct 11, 2004 11:09 PM
