Wow. Very interesting. I wouldn't have ever thought you'd be getting condensate in the CC.
Temps have been down in the 20's to 40's. We have had snow three times since I put it on.
I have driven well over 100 miles in 4x4 alone.
I know there are no leaks since the inside was totally clean whereas the outside is looking pretty dirty now with all the road grime due to snow and slush.
So, all the discussions about the CCV mod got my curiosity up, so last weekend I ran an external vent.
The question I have, is there any real concern with the extra line running out of the engine bay and the condensation freezing in the line? I live in Minnesota, so it tends to cool off pretty good.
If this is a realistic concern, would there be any parameter that would worn of this before it becomes a major issue?
If this is a concern, I would think it would be a concern for either an external vent or a filtered, extended return line.
Ive also noticed that according to Racor, The CCV4500 is only rated for a max of 400HP. I wonder if a guy wouldnt want to use the CCV6000 Wich is rated for 800HP instead? Any thoughts on this?
It certainly would be a consideration. I don't pull 400HP so the 4500 is fine for me.
Scott,
Just to make sure I am following your install here, you installed a Racor that is a CLOSED system as it runs back into the intake? If so, I understand, I don't want mine vented to the atmosphere either, but was just wondering as I saw the intake had a hose coming back to it. Most that vent to the atmosphere just plug it off the intake port.. I am trying to get the Flo-Pro cold side pipe in sometime soon, and was thinking of doing this CCV mod.
Scott,
YES, I have the hose coming off the fill canister going down by the air box to the passenger rail under the door. There it connects to the cannister which is then re-routed back up to the intake.
I did this as I was beginning to notice the oily residue around the cac hoses from the buildup.
Unfortunatly I still had to replace one of them because I waited too long.
Brown Dog Ktm. I just removed the same ccv system you have pictured there. The mesh screen inside came apart and hopefully none of it went into the engine. Pull that polished piece off the top and take a look at yours. I cant seem to find that company online anymore.
No worries, I have no interest in running their product again. Just warning you guys to check yours as that thing coming apart can ruin an engine if it gets sucked into the intake.
